Corsair RM Series power supplies are fully modular and optimized for silence and high efficiency. Zero RPM Fan Mode means that the fan doesn't even spin until the power supply is under heavy load, and the fan is custom-designed for low noise operation even at high loads. 80 PLUS Gold rated efficiency saves you money on your power bill, and the flat black cables are fully modular, so you can enjoy fast, neat builds. And, like all Corsair power supplies, RM Series is built with high-quality components and is guaranteed to deliver clean, stable, continuous power. Connect it to your Corsair Link system and you can even monitor fan speed and +12V current directly from your desktop (additional cable required for 450W-850W units).
Optimized for Silence
The efficient design of the RM Series means minimal excess heat generation, and thanks to the Zero RPM fan mode the fan doesn't even need to spin under low to medium loads. The custom-designed fan has an optimized blade profile for low-turbulence airflow and near-silent operation even at full speed. And when you're pushing it hard, the thermal sensor controls the fan speed to ensure that it gets the cooling it needs without any extra noise.
The components used to manufacture the RM Series are manufactured specifically for excellent performance and low audible noise.
80 PLUS Gold-certified Efficiency
Highly efficient RM Series power supplies produce less heat and have lower operating costs.
Flat black, Low-Profile Modular Cables
You can use only the cables you need, and leave the rest in the box for fast, easy, and great-looking builds.
Reliable, Continuous Power Delivery
RM Series power ratings are continuous, not peak, for superior protection for your valuable PC. Corsair uses high-quality internal components, and RM Series power supplies are guaranteed to deliver clean, stable, continuous power.
Corsair Link Compatible
Want even more? RM Series power supplies connect to Corsair Link software for real-time monitoring of fan speed and power delivery directly from your desktop. Additional hardware required for 450W-850W units. See corsair.com for more details.
Tech Specs
- The latest ATX12V v2.4 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2, 2.31 and ATX12V 2.01 systems.
- 4th generation Intel® Core™ processor Ready (Intel Haswell and Z78 motherboards)
- 80PLUS Gold certified, delivering over 92% energy efficiency at real world load conditions.
- The completely modular cable system allows you to use only the cables you need.
- Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer's chassis.
- High-quality capacitors provide uncompromised performance and reliability.
- A five year warranty and lifetime access to Corsair's legendary technical support and customer service.
- Active Power Factor Correction (PFC) with PF value of 0.99.
- 135MM NR135L Noise reducing fan. MTBF: 100,000 Hours
- Universal AC input from 100~240V.
- Multi-GPU Ready
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system components.
- Safety and Agency Approvals: FCC, ICES, CE, C TUV US, RCM, TUV, CB, CCC, BSMI, GOST, ROHS, WEEE, ROHS, KC
High-quality, low-noise capacitors and transformers
RM series power supplies are designed with capacitors and transformers carefully selected to eliminate coil whine and other background noise that can be annoying in quiet environments. -
Zero RPM fan mode
The efficient design of the RM550 means minimal excess heat generation, so the fan doesn't even need to spin under low to medium loads. And when you're pushing it hard, the thermal sensor controls the fan speed to ensure that it gets the cooling it needs without any extra noise. -
Corsair NR135L noise-reducing fan
The custom-designed fan has an optimized blade profile for low-turbulence airflow and near-silent operation even at full speed. -
80 PLUS Gold-certified efficiency
Highly efficient RM series power supplies produce less heat and have lower operating costs. -
Flat black, low-profile modular cables
You can use only the cables you need, and leave the rest in the box for fast, easy, and great-looking builds. -
Reliable, continuous power delivery
Power ratings are continuous, not peak, for superior protection for your valuable PC. Corsair uses high-quality internal components, and the RM550 is guaranteed to deliver clean, stable, continuous power.
- CORSAIR RM550 - power supply - 550 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.4/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Gold
- 2.09 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 550 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V - 45.8 A , -12V - 0.8 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector , 2 x 8 pin PCI Express power with detachable 2 pin section
- Modular Cable Management
- Included Accessories
- Cable ties, mounting kit, cable bag
- 15 cm x 16 cm x 8.6 cm
- 5-year warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 550 Watt
- Output Current
- Efficiency
- 92%
- 80 PLUS Gold
- Cables Included
- Power cable kit
- MTBF
- 100,000 hours
- Corsair Link, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, Multi-GPU Technologies Supported, temperature controlled fan, Zero RPM fan mode, fully modular
- TUV, BSMI, GOST, TUV S, CB, CCC, FCC, RoHS, WEEE, ICES, cTUVus, KC
- Limited warranty - 5 years
- 15 cm
- 16 cm
- 8.6 cm
- 2.09 kg
- Shipping Weight
- 2.49 kg
