The powerful touchscreen technology is integrated into the screen enabling it to be dual touch, allowing multiple users. The Clevertouch range does not require drivers, calibration or set up. The crystal clear resolution and high brightness display means that images are clearly visible and unlike projection based interactive solutions, there is no shadowing.
The Clevertouch LED features a slimmer bezel, lower power consumption and a lighter weight, whilst still being as tough and durable as the Clevertouch LCD.
- Clevertouch Plus 65" LED-backlit LCD display - Full HD
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 65"
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Storage Capacity
- 8 GB Flash
- USB
- 4 ports
- Included Accessories
- Remote control, pen stylus, CleverLynx with Wordwall, DisplayNote Presenter Licence
- Voltage
- AC 120/230 V (50/60 Hz)
- 265 Watt
- Power Consumption Stand by
- 0.5 Watt
- 154.5 cm x 10.5 cm x 94.2 cm
- 72 kg
- Product Type
- 265 Watt
- Diagonal Class
- 65"
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- 154.5 cm
- 10.5 cm
- 94.2 cm
- 72 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare
- Colour Depth
- 10-bit colour
- Image Contrast Ratio
- 4000:1
- Brightness
- 360 cd/m²
- Viewing Angle
- 178 degrees
- Touchpoints Qty
- 10
- Response Time
- 8 ms
- Backlight Life
- 50,000 hour(s)
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 4
- Configuration
- ARM Cortex-A9 Dual-Core - 1.5 GB DDR3 - 8 GB Flash
- Operating System
- Android OS 4.2.1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connect & Share
- Wireless HD Ready (WHDI)
- Connector Type
- 3 x VGA input , 3 x audio input , Serial , 3 x USB 2.0 , USB 3.0 , LAN , 3 x HDMI input , Composite video input , VGA output , Audio line-in , Headphones , Digital audio input (coaxial)
- Pen stylus, CleverLynx with Wordwall, DisplayNote Presenter Licence
- Cables Included
- VGA cable - 5 m , USB cable - 5 m , Audio cable - 5 m , HDMI cable - 1.5 m
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Width (Shipping)
- 170 cm
- Depth (Shipping)
- 21.5 cm
- Height (Shipping)
- 110 cm
- Weight (Shipping)
- 82 kg
