Easily build a highly reliable network to connect your computers, printers, copiers, and other office equipment. If your business is like most small companies, you do not have an IT staff to set up your network for you. Now you can have a high-performance, business-class office network that just works, right out of the box, with the Cisco 110 series Unmanaged Switches. Users, workgroups, labs, departments, or growing offices can now deliver large amounts of multimedia, image, and video information across the network in almost no time.
Cisco 110 series Unmanaged Switches deliver basic network connectivity and reliability for small businesses that is easy on the budget and without all the complexity. These switches provide all of the features, expandability, and investment protection you expect from Cisco, with no installation software and nothing to configure. Just plug it in, connect your computers and other business equipment, and get to work.
Cisco 110 series Unmanaged Switches, part of the Cisco Small Business networking solutions, are a line of unmanaged switches that provide wire-speed Fast Ethernet and Gigabit Ethernet connectivity to connect your small business office. They use less power and provide the robust, reliable connectivity your business demands, as well as support for advanced features such as quality of service (QoS), loop detection, and cable diagnostics, all in a switch that you can set up yourself in minutes. A business-class, affordable network solution, Cisco 110 series switches bring the proven reliability and investment protection of Cisco networking solutions to your small business.
ETHERNET PORT CONFIGURATION
16-port 10/100/1000 Gigabit -
POWER OVER ETHERNET
8 PoE ports with 64W total power budget -
PLUG AND PLAY
Simple set up with no software to install or configuration needed -
PEACE OF MIND
Limited-lifetime warranty and one-year technical support -
SUPPORTED AUTOMATIC FEATURES
Quality of service (QoS), loop detection, and cable diagnostics
- Cisco Small Business SG110-16HP - switch - 16 ports - unmanaged
- Switch - 16 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 + 8 x 10/100/1000 (PoE)
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 64 W
- Performance
- Switching capacity: 32 Gbps , Forwarding performance (64-byte packet size): 23.8 Mpps
- Capacity
- QoS hardware queues: 4
- Jumbo Frame Support
- 9216 bytes
- QoS, Energy Efficient Ethernet, security lock slot (cable lock sold separately), cable test
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V (50 - 60 Hz)
- 27.94 cm x 17 cm x 4.45 cm
- 1.43 kg
- Localisation
- Europe
- Limited lifetime warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- PoE Budget
- 64 W
- Performance
- Capacity
- 9216 bytes
- RAM
- 128 MB
- Flash Memory
- 128 MB
- Status Indicators
- Power, system, PoE, link/activity, diagnostic, loop
- 8 x 1000Base-T RJ-45 , 8 x 1000Base-T RJ-45 PoE
- Power Device
- Internal power supply
- Voltage Required
- UL 60950, FCC CFR47 Part 15, CSA 22.2
- Localisation
- Europe
- 27.94 cm
- 17 cm
- 4.45 cm
- 1.43 kg
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
Cisco Gigabit Ethernet LX Mini-GBIC SFP Transceiver | In Stock | £142.31 |
