Cisco RV 120W Wireless-N VPN Firewal
Quicklinx: 7D1HWS00 Mfr#: RV120W-E-G5
  • IEEE 802.11n
The Cisco RV 120W Wireless-N VPN Firewall combines highly secure connectivity - to the Internet as well as from other locations and remote workers - with a high-speed, 802.11n wireless access point, a 4-port switch, an intuitive, browser-based device manager, and support for the Cisco FindIT Network Discovery Utility, all at a very affordable price. Its combination of high performance, business-class features and top-quality user experience takes basic connectivity to a new level.
Cisco Small Business RV120W - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Performance
NAT throughput: 100 Mbps , VPN throughput (IPSec): 25 Mbps
Concurrent sessions: 1000 , IPSec VPN tunnels: 10 , VPN tunnels: 10
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, Bonjour, DDNS
Routing Protocol
RIP-1, RIP-2, IGMP, static IP routing
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
VoIP Protocols
SIP
Switching, NAT support, VPN support, PAT support, SPI, content filtering, IPv6 support, VPN passthrough, firmware upgradable, SNTP support, WMM support, QoS, DHCP server, DNS proxy, port forwarding, IPv4 support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, X.509, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, UPnP
DC 12 V 1 A
15 cm x 15 cm x 3.4 cm
499 g
Europe
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Selectable Channels Qty
13
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, AES, SHA-1, PEAP, WPA2
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, X.509, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, UPnP, FCC Class B certified, ICES-003
Status Indicators
Power, WAN, LAN, wireless
IP Telephony
VoIP Protocols
SIP
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
2
Directivity
Omni-directional
Gain Level
1.8 dBi
External power adapter
DC 12 V
Electric Current Required
1 A
1 x network cable
Europe
OS Provided
Linux
Software Included
Cisco QuickVPN Client
15 cm
15 cm
3.4 cm
499 g
Limited warranty - lifetime
10 - 85%
