Cisco Catalyst 3560G-48PS SMI - switch - 48 ports
Quicklinx: 40G7WS00 Mfr#: WS-C3560G-48PSS
The Cisco Catalyst 3560 Series is a line of fixed-configuration, enterprise-class switches that include IEEE 802.3af and Cisco prestandard Power over Ethernet (PoE) functionality in Fast Ethernet and Gigabit Ethernet configurations. The Cisco Catalyst 3560 is an ideal access layer switch for small enterprise LAN access or branch-office environments, combining both 10/100/1000 and PoE configurations for maximum productivity and investment protection while enabling the deployment of new applications such as IP telephony, wireless access, video surveillance, building management systems, and remote video kiosks. Customers can deploy networkwide intelligent services-such as advanced quality of service (QoS), rate limiting, access control lists (ACLs), multicast management, and high-performance IP routing-while maintaining the simplicity of traditional LAN switching.
Cisco Catalyst 3560G-48PS - switch - 48 ports - Managed
Switch - 48 ports - L3 - Managed
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE) + 4 x Gigabit SFP
Power Over Ethernet (PoE)
PoE
Performance
Forwarding performance (64-byte packet size): 38.7 Mpps
MAC Address Table Size
12K entries
Routing Protocol
RIP-1, RIP-2, HSRP, static IP routing, RIPng
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, SSH-2
Full duplex capability, Layer 3 switching, Layer 2 switching, auto-sensing per device, IP-routing, DHCP support, PoE, auto-negotiation, ARP support, trunking, MPLS support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, traffic shaping, manageable, STP support, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, TFTP support, ACL support, QoS, DHCP server, VRF-Lite, MLD snooping, DAI, TDR, PVST+, Cisco EnergyWise technology, UDLD, LACP
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
44.5 cm x 40.9 cm x 4.4 cm
7 kg
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
PoE
Performance
12K entries
Routing Protocol
Authentication Method
Kerberos, RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
128 MB
Flash Memory
32 MB Flash
Status Indicators
Port transmission speed, port duplex mode, system, RPS (Redundant Power Supply), PoE, link/activity
48 x 1000Base-T RJ-45 PoE , 1 x console RJ-45 management , 4 x SFP (mini-GBIC)
Internal power supply
590 watt
Redundant Power System (RPS) connector
MTBF
147,000 hours
FCC Class A certified, TUV GS, GOST, BSMI CNS 13438 Class A, CISPR 24, cUL, NOM, VCCI Class A ITE, EN55024, EN55022 Class A, CISPR 22, CSA 22.2 No. 60950, CB, AS/NZS 60950-1, AS/NZ 3548 Class A, EMC, FCC Part 15, MIC, UL 60950-1, IEC 60950-1, EN 60950-1
Software Included
Cisco IOS IP Base
44.5 cm
40.9 cm
4.4 cm
7 kg
Limited warranty - lifetime
45 °C
10 - 85% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
40G7 Cisco AC Power Cord (UK), C13, BS 1363, 2.5m In Stock £35.26
Resources
The following resources are available for the Cisco Catalyst 3560G-48PS SMI - switch - 48 ports
