Cisco Catalyst 2960-24TT - switch - 24 ports
Quicklinx: 40VFWS00 Mfr#: WS-C2960-24TT-L
Cisco Catalyst 2960 Series Intelligent Ethernet Switches are a new family of fixed-configuration standalone devices that provide desktop Fast Ethernet and Gigabit Ethernet connectivity, enabling enhanced LAN services for entry-level enterprise, mid-market, and branch office networks. The Catalyst 2960 Series offers integrated security, including network admission control (NAC), advanced quality of service (QoS), and resiliency to deliver intelligent services for the network edge.
Cisco Catalyst 2960-24TT - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 + 2 x 10/100/1000
Performance
Switching capacity: 32 Gbps , Forwarding performance (64-byte packet size): 6.5 Mpps
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH
Layer 2 switching, auto-sensing per device, dynamic IP address assignment, auto-negotiation, BOOTP support, ARP support, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, RSTP support, MSTP support, DHCP snooping, DTP support, PAgP support, ACL support, QoS, LACP, Port Security, MAC Address Notification, RSPAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1ab (LLDP)
44.5 cm x 23.6 cm x 4.4 cm
3.63 kg
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
Performance
8K entries
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
64 MB
Flash Memory
32 MB Flash
Status Indicators
Port transmission speed, port duplex mode, power, link OK, system, link/activity
24 x 100Base-TX RJ-45 , 2 x 1000Base-T RJ-45
Internal power supply
28 watt
Rack Mounting Kit
Optional
MTBF
407,707 hours
TUV GS, CISPR 22 Class A, GOST, BSMI CNS 13438 Class A, CISPR 24, NOM, VCCI Class A ITE, EN55024, CB, EMC, MIC, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, RoHS, CSA C22.2 No. 60950-1, FCC Part 15 B Class A
Software Included
Cisco LAN Base software
44.5 cm
23.6 cm
4.4 cm
3.63 kg
Limited warranty - lifetime
-5 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
40VF Cisco AC Power Cord (UK), C13, BS 1363, 2.5m In Stock £35.26
40VF Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £80.04
