Your basket is empty
Cisco ASA 5520 Security Appliance
Quicklinx: 4CTHWS00 Mfr#: ASA5520-BUN-K9
19 in stock
£3,418.80 ex VAT
£4,102.56 inc VAT
The Cisco ASA 5520 Adaptive Security Appliance delivers a wide range of security services with Active/Active high availability and Gigabit Ethernet connectivity for medium-sized enterprise networks, in a modular, high performance appliance. Using its four Gigabit Ethernet interfaces and support for up to 25 VLANs, businesses can easily deploy these security services into multiple zones within their network. The Cisco ASA 5520 Adaptive Security Appliance scales with businesses as their network security requirements grow, delivering solid investment protection. Businesses can extend their IPSec and SSL VPN capacity through multiple means to support a larger number of mobile workers, remote sites, and business partners. VPN capacity can be increased by taking advantage of the integrated VPN clustering and load-balancing capabilities of the Cisco ASA 5520 Adaptive Security Appliance, as well as more than doubling each platform's VPN capacity through the installation of a VPN upgrade license. The advanced application layer security and anti-x defenses provided by the Cisco ASA 5520 Adaptive Security Appliance can be extended by deploying a high performance Security Services Module. Using the optional security context capabilities of the Cisco ASA 5520 Adaptive Security Appliance, businesses can deploy up to 10 virtual firewalls within an appliance to enable compartmentalized control of security policies on a departmental level. This virtualization strengthens security and reduces overall management and support costs while consolidating multiple security devices into a single appliance.
Cisco ASA 5520 Firewall Edition - security appliance
Security appliance
Enclosure Type
Rack-mountable - 1U
44.5 cm x 33.5 cm x 4.4 cm
9.1 kg
RAM Installed ( Max )
2 GB
Flash Memory Installed (Max)
256 MB Flash
Network / Transport Protocol
IPSec
Performance
Firewall throughput : 450 Mbps , VPN throughput : 225 Mbps , Connection rate : 12000 connections per second
Concurrent sessions : 280000 , IPSec VPN peers : 750 , SSL VPN peers : 2 , Virtual interfaces (VLANs) : 100
Firewall protection, VPN support, load balancing, VLAN support, High Availability
AC 120/230 V ( 50/60 Hz )
Security appliance
Height (Rack Units)
1U
Installed Modules Qty (Max)
0 ( 1 )
44.5 cm
33.5 cm
4.4 cm
9.1 kg
Processor / Memory / Storage
2 GB
256 MB Flash
Rack-mountable
Wired
IPSec
Performance
Encryption Algorithm
DES, Triple DES, AES
Expansion Slot(s)
1 (total) / 1 (free) x Expansion Slot , 1 memory
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x management - console - RJ-45 , 2 x Hi-Speed USB - 4 PIN USB Type A , 1 x serial - auxiliary - RJ-45 , 4 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45
FCC Class A certified, CISPR 22 Class A, EN 60950, EN 61000-3-2, UL 1950, VCCI Class A ITE, IEC 60950, EN 61000-3-3, CSA 22.2 No. 950, EN55022 Class A, ACA TS001, AS/NZS 3260, FCC Part 15
Power supply - internal
Power Provided
190 Watt
5 - 95%
* Compared to buying items separately
Options (1)
4CTH Cisco ASA 5500 / IPS 4200 4-PORT GIGABIT ETHERNET SSM In Stock £1,919.53
Brand: Cisco
Price Range Ex VAT: 1500+
