The Cisco AP 541N is a 802.11n dual-band clustering access point built for small businesses. The clustering capability makes it easy to set up, configure, and manage a growing wireless network. You can deploy multiple access points and push a single configuration to all the devices within the cluster, managing your wireless network as a single system without worrying about interference between access points, and without having to configure each access point as a separate device.
The Cisco AP 541N is a versatile, high-performance wireless solution that supports virtually any wireless application your business requires, including mobile data, voice over wireless LAN, wireless video monitoring, and highly secure guest access. It can be used as a standalone access point in small wireless environments or deployed as part of a larger data and communications network, such as the Cisco Smart Business Communication System (SBCS). Designed to integrate with other solutions in the Cisco Small Business Pro series, it makes even advanced wireless and communications applications easy to install, configure, and support.
Robust wireless coverage and performance
The Cisco AP 541N is an 802.11n multiple-input, multiple-output (MIMO) dual-band wireless solution. The 802.11n wireless standard builds on previous-generation (802.11a/b/g) wireless technologies to deliver greater range and reliability, and up to nine times the performance. Where previous wireless technologies communicate over a single stream and antenna, Wireless-N MIMO solutions transmit and receive over multiple antennas to provide much greater resiliency and data throughput. -
Advanced clustering intelligence
Clustering is the ability of a wireless access point to form a dynamic, configuration-aware group (called a cluster) with other similarly designed access points in the same network and subnet. All access points in the cluster self-organize, cloning configuration settings from one access point to another and balancing wireless channels to minimize radio interference. The cluster also provides a single point of administration, allowing you to configure and manage all access points as a single wireless network, rather than as a collection of individual devices - without the need for a wireless controller. -
Highly secure guest access
In a world where technology touches virtually every aspect of business operations, vendors and customers often need to access the Internet when visiting your business location. The Cisco AP 541N includes an easy-to-follow graphical user interface (GUI) to guide you through the setup of a guest network. This highly secure guest access solution lets visitors get online without granting them any visibility into your business network and without impeding the performance of your business applications. The solution even lets you provide a welcome screen to greet visitors using your guest network. -
Simple setup and configuration
The Cisco AP 541N is designed to easily integrate with other Cisco Small Business Pro series solutions and the Cisco SBCS, allowing you to implement even advanced voice and video applications quickly and easily. The solution includes an intuitive GUI to guide you through each step in an implementation, and lets you configure your entire wired and wireless environment from a single interface, using the Cisco configuration assistant. -
Strong security
Cisco AP 541N access points include robust security features. Features include advanced Wi-Fi Protected Access (WPA2) encryption, rogue access point detection, access control lists, and MAC address filtering. -
Deployment flexibility
The Cisco AP 541N can operate using either standard AC power or Power over Ethernet (PoE) to support virtually any deployment. With PoE, you can connect and power access points with a single Ethernet cable, simplifying installations in locations such as drop ceilings where power outlets may not be accessible. -
Scalable design
Designed to operate as either a standalone wireless access point or as part of a larger business network, the Cisco AP 541N can meet virtually any business requirement, from small basic deployments to elaborate wireless voice and video installations. This flexibility, along with the ability to easily add wireless access points, means that the Cisco AP 541N solution will grow with your business as your needs change, while minimizing operational costs. -
An integrated solution
As part of the Cisco Small Business Pro Series, the Cisco AP 541N works with other Cisco Small Business Pro series products to deliver powerful, integrated systems that are competitively priced and easy to deploy and manage. Individually, each Cisco Small Business Pro series product solves a small business need and delivers peace of mind. Together, they form a strong, versatile technology foundation that you can build on as your communications needs change.
- Cisco Small Business Pro AP541N - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Localisation
- European Union
- RAM
- 64 MB
- Flash Memory
- 32 MB
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- AC 120/230 V (50/60 Hz)
- 30.1 cm x 18 cm x 4.4 cm
- 1.3 kg
- 1-year warranty
- 30.1 cm
- 18 cm
- 4.4 cm
- 1.3 kg
- Localisation
- European Union
Processor / Memory / Storage
- RAM
- 64 MB
- Flash Memory
- 32 MB
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Spread Spectrum Method
- OFDM, DSSS
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3
- Status Indicators
- Port status, port transmission speed, power
- DHCP support, load balancing, VLAN support, Syslog support, firmware upgradable, MIMO technology, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), wireless bridge mode
- Encryption Algorithm
- 64-bit WEP, WPA-PSK, 128-bit AES, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
- RADIUS, Basic Service Set Identifier (BSSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
Aerial
- Antenna
- External detachable
- Antenna Qty
- 3
- Directivity
- Omni-directional
- Gain Level
- 2 dBi
- 1 x 1000Base-T - RJ-45
- Cables Included
- 1 x network cable
- RSS-210, IC, ICES-003 Class A, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, EN 300 328, EN 301 489-1, EN 301 893, EN 301 489-17
- PoE
- Power Device
- External power adapter
- Voltage Required
- OS Provided
- Linux
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 85%
