Cisco Aironet 1832I Radio Access Point 802.11ac (draft 5.0)
Quicklinx: CP68WS00 Mfr#: AIR-AP1832I-E-K9
Type: Radio access point
Connectivity: Wireless
Speed: 1Gbps
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a + 1 more
Compatibility: PC
  • IEEE 802.11n
£536.76 ex VAT
£644.11 inc VAT
Ideal for small and medium-sized networks, the Cisco Aironet 1830 series delivers great wireless performance with support for the advanced Wi-Fi standard, and meets the growing requirements of wireless networks by delivering a better user experience. The 1830 series extends support to a generation of Wi-Fi clients, such as smartphones, tablets, and high-performance laptops that have integrated 802.11ac support. With 802.11ac Wave 2, the 1830 series provides a high data rate, exceeding the data rates offered by high-end 802.11n access points. It also enables a total aggregate dual-radio data rate, providing the necessary foundation for enterprise and service provider networks to stay ahead of the performance and bandwidth expectations and needs of their wireless users. Due to its convenience, wireless access is increasingly the preferred form of network connectivity for corporate users. Along with this shift, there is an expectation that wireless should not slow down users' day-to-day work, but should enable a high-performance experience while allowing users to move freely. The 1830 series delivers amazing performance for highly secure and reliable wireless connections and provides a robust mobility experience.
  • MU-MIMO
    802.11ac Wave 2 with 3x3 Multiple-Input Multiple-Output (MIMO) technology with two spatial streams when operating in single-user or multi-user MIMO mode, offering 867 Mbps rates for more capacity and reliability than competing access points
  • APPLICATION VISIBILITY AND CONTROL
    Network Based Application Recognition (NBAR) deep-packet inspection technology provides application-aware control on a wireless network and enhances manageability and productivity. It also extends Cisco's Application Visibility and Control (AVC) as an end-to-end solution, which gives a complete visibility of applications in the network and allows the administrator to take some action on the same.
  • RADIO RESOURCE MANAGEMENT
    Cisco's Radio Resource Management (abbreviated RRM) allows Cisco's Unified WLAN Architecture to continuously analyse the existing RF environments, automatically adjusting each AP's power and channel configurations to help mitigate things such as co-channel interference and signal coverage problems. RRM reduces the need to perform exhaustive site surveys, increases system capacity and provides automated self-healing functionality to compensate for RF dead zones and AP failures
  • SECURITY
    Securing the Device: Cisco Umbrella (OpenDNS), Identity PSK (iPSK), IP and DNS ACLs. Securing the Air: Spectrum Intelligence, Wireless Intrusion Detection (WIDS). Securing the Network: 802.1x on AP, AAA profiling and policy
  • PEACE OF MIND
    Limited lifetime hardware warranty
Cisco Aironet 1832I - radio access point - Wi-Fi 5
Radio access point
External - indoor
Belgium, Bahrain, Lebanon, Oman, Saudi Arabia, United Arab Emirates, Bulgaria, Czech Republic, Estonia, Lithuania, South Africa, Iceland, Romania, Sri Lanka, Luxembourg, Hungary, Cyprus, Iraq, Ghana, Kenya, Nigeria, Liechtenstein, Gibraltar, Malta, Monaco, Croatia, Slovakia, Slovenia, Latvia, Libya, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Spain, Sweden, Switzerland, United Kingdom, Greece, Turkey, Ireland, Serbia, Montenegro, Bosnia and Herzegovina
RAM
1 GB
Flash Memory
256 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 5.0)
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE+
AC 100-240/ DC 44-57 V (50 - 60 Hz)
21.08 cm x 21.08 cm x 50.8 cm
1.41 kg
Radio access point
Ruggedized Design
Indoor
21.08 cm
21.08 cm
50.8 cm
1.41 kg
Processor / Memory / Storage
RAM
1 GB
Flash Memory
256 MB
External
Wireless
Data Transfer Rate
1 Gbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
DFS support, Wi-Fi Multimedia (WMM) support, Maximum Ratio Combining (MRC), 3T3R MIMO technology, 802.1x authentication, cyclic shift diversity (CSD), beamforming technology
Encryption Algorithm
AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2
Authentication Method
MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac (draft 5.0)
Aerial
Antenna
Internal
Directivity
Omni-directional
Gain Level
5 dBi
1 x 1000Base-T (PoE+) - RJ-45 , 1 x console - RJ-45 , 1 x USB 2.0 - Type A
VCCI, ICES-003, FCC Part 15.247, RSS-210, RSS-102, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, ARIB STD-T66, ARIB STD-T71, EMI, EN 300 328, FCC OET Bulletin 65c, EN 301 489-1, CAN/CSA-C22.2 No. 60950-1
PoE+
External power adapter
16 Watt
10 - 90% (non-condensing)
CP68 Cisco Ceiling Grip Clip In Stock £15.09
Speed: 1Gbps
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac (draft 5.0)
Compatibility: PC
Brand: Cisco
Price Range Ex VAT: £500 - £750
