Cisco Aironet 1242 Integrated Auto Access Point
Quicklinx: 5KK4WS00 Mfr#: AIR-AP1242G-EK9
  • Wi-Fi CERTIFIED
Cisco Aironet 1240G Series Access Points provide single-band 802.11g wireless connectivity for challenging RF environments such as factories, warehouses, and large retail establishments. Connectorized antennas, a rugged metal enclosure, and a broad operating temperature range offer extended range and coverage versatility. The Cisco Aironet 1240G Series provides local as well as inline power, including support for IEEE 802.3af Power over Ethernet (PoE).
The Cisco Aironet 1240G Series is a component of the Cisco Unified Wireless Network, a comprehensive solution that delivers an integrated, end-to-end wired and wireless network. Using the radio and network management features of the Cisco Unified Wireless Network for simplified deployment, the Cisco Aironet 1240G Series extends the security, scalability, reliability, ease of deployment, and manageability available in wired networks to the wireless LAN (WLAN).
Cisco Aironet 1242G - radio access point - Wi-Fi
Radio access point
External
RAM
32 MB
Flash Memory
16 MB
IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
16.8 cm x 21.6 cm x 2.8 cm
0.9 kg
90 days warranty
Radio access point
16.8 cm
21.6 cm
2.8 cm
0.9 kg
Processor / Memory / Storage
RAM
32 MB
Flash Memory
16 MB
External
Wireless
Data Transfer Rate
54 Mbps
Line Coding Format
CCK, OFDM
Spread Spectrum Method
OFDM
Remote Management Protocol
SNMP, Telnet, HTTPS
Frequency Band
2.4 GHz
Max Range Indoors
140 m
Max Range Open Space
290 m
Selectable Channels Qty
13
Status Indicators
Active, error, status
Auto-sensing per device, auto-negotiation
Encryption Algorithm
LEAP, 128-bit WEP, 40-bit WEP, TLS, PEAP, TTLS, TKIP, WPA, WPA2, AES-CCMP
IEEE 802.3, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
Antenna - RP-TNC , 1 x network / power: - 10Base-T/100Base-TX
PoE
External power adapter
13 Watt
Limited warranty - 90 days
-20 °C
55 °C
10 - 90%
