Cisco Aironet 1131G Integrated Auto Access Point
Quicklinx: 6368WS00 Mfr#: AIR-AP1131G-EK9
The Cisco Aironet 1130G Series Access Point is a single-band 802.11g access point that features business-class management, security, and scalability. This low-profile access point offers high-performance wireless connectivity in offices and similar environments.
The Cisco Aironet 1130G Series delivers optimal value for offices and similar environments. Built-in antennas provide omnidirectional coverage specifically designed for today's open workspaces. A multipurpose mounting bracket easily secures Cisco Aironet 1130G Series Access Points to ceilings and walls. With an unobtrusive design, Cisco Aironet 1130G Series Access Points are aesthetically pleasing and blend into their environments. For maximum concealment, the access point can be placed above ceilings or suspended ceilings. The UL 2043 rating of the Cisco Aironet 1130G Series allows for placement of the access point above ceilings in plenum areas regulated by municipal fire codes. Offered at a competitive price and optimized for easy installation and operation, the Cisco Aironet 1130G Series helps organizations attain a lower total cost of ownership.
Cisco Aironet 1131G - radio access point - Wi-Fi
Radio access point
External
Europe
RAM
32 MB
Flash Memory
16 MB
IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
19.1 cm x 3.3 cm x 19.1 cm
0.67 kg
90 days warranty
Radio access point
19.1 cm
3.3 cm
19.1 cm
0.67 kg
Europe
Processor / Memory / Storage
RAM
32 MB
Flash Memory
16 MB
External
Wireless
Data Transfer Rate
54 Mbps
Line Coding Format
CCK, OFDM
Spread Spectrum Method
OFDM, DSSS
Remote Management Protocol
SNMP, Telnet, HTTPS
Frequency Band
2.4 GHz
Max Range Indoors
137 m
Max Range Open Space
290 m
Selectable Channels Qty
13
Status Indicators
Active, error, status
Auto-sensing per device, BOOTP support
Encryption Algorithm
LEAP, AES, 128-bit WEP, 40-bit WEP, TLS, PEAP, TKIP, WPA, WPA2
IEEE 802.3, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
Aerial
Antenna
Internal
Directivity
Omni-directional
Gain Level
3 dBi
1 x 100Base-TX (PoE) - RJ-45
ETSI, VCCI, ICES-003, RSS-210, FIPS 140-2 Level 2, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, EN 300 328, EN 301 489-1
PoE
External power adapter
9.9 Watt
OS Provided
Cisco IOS
Limited warranty - 90 days
10 - 90%
