Cisco 891F ISDN/Mdm Desktop/Rack-Mountable Router
Quicklinx: BDWFWS00 Mfr#: C891F-K9
£993.44 ex VAT
£1,192.12 inc VAT
Cisco 890 Series Integrated Services Routers (ISRs) are fixed-configuration routers that provide collaborative business solutions for secure voice and data communications to enterprise small branch offices. They are designed to deliver secure broadband, Metro Ethernet, wireless LAN (WLAN) connectivity, and business continuity. The routers also come with powerful management tools, such as the web-based Cisco Configuration Professional configuration management tool, which simplifies setup and deployment. Centralized management capabilities give network managers visibility and control of the network configurations at the remote site.
  • PORT COUNT
    8-port managed Gigabit Ethernet switch (4 ports PoE capable with 125W power supply adapter)
  • CONNECTIVITY
    Integrated 802.11n access point supports both autonomous and unified modes
  • SECURITY
    VPN; firewall support for highly secure remote-access client connectivity
  • PERFORMANCE
    Business router designed to run multiple services simultaneously with no performance degradation
  • PEACE OF MIND
    1-year limited hardware warranty with 10-day advanced replacement
Cisco 891F - router - ISDN/Mdm - desktop, rack-mountable
Router - ISDN / analogue modem combo - 8-port switch (integrated)
Enclosure Type
Desktop, rack-mountable - 1U
IPSec VPN tunnels: 50
Network / Transport Protocol
L2TP, RSVP, ICMP/IP, IPSec, FTP, DHCP, DNS, L2TPv3, DDNS, RTP
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, EIGRP, HSRP, VRRP, NHRP, GRE, OSPFv3, policy-based routing (PBR), BGP-4+, WCCP, Bidirectional Forwarding Detection (BFD)
Remote Management Protocol
Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI
Firewall protection, NAT support, PoE, auto-uplink (auto MDI/MDI-X), IGMP snooping, traffic shaping, dynamic DNS server, DiffServ support, MAC address filtering, IPv6 support, High Availability, IPS, LLQ, CBWFQ, WFQ, WRED, STP support, ACL support, QoS, LFI, DMVPN, DHCP server, VRF-Lite, DNS proxy, fanless, DHCP relay, DHCP client, CoS, FNF, security lock slot (cable lock sold separately), DSCP support, Storm Control
IEEE 802.1D, IEEE 802.1Q, IEEE 802.3af, IEEE 802.1x
32.5 cm x 24.9 cm x 4.4 cm
2.5 kg
1-year warranty
Router - 8-port switch (integrated)
Enclosure Type
Wired
Routing Protocol
Encryption Algorithm
DES, Triple DES, SSL, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
RADIUS, TACACS+
IEEE 802.1D, IEEE 802.1Q, IEEE 802.3af, IEEE 802.1x, CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN50082-1, EN 61000-6-1, KN22, EN 300386
RAM
512 MB (installed) / 1 GB (max)
Flash Memory
256 MB
Communications
Protocols & Specifications
ITU V.92
Management: 1 x console - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , LAN: 4 x 10Base-T/100Base-TX/1000Base-T (PoE) - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x SFP (mini-GBIC) , WAN: 1 x BRI ST , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x modem - RJ-11
External power adapter - 60 Watt
OS Provided
Cisco IOS Advanced IP services
32.5 cm
24.9 cm
4.4 cm
2.5 kg
Limited warranty - advance parts replacement - 1 year - response time: 10 days
10 - 85% (non-condensing)
Accessories (1)
Get the most from your Router
BDWF Cisco 1000BASE-T SFP Transceiver In Stock £199.93
Other bundles (1)
BDWF Cisco AC Power Cord (UK), C13, BS 1363, 2.5m In Stock £40.21
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Brand: Cisco
Price Range Ex VAT: £750 - £1000
