An entry level member of the Cisco Integrated Services Router Generation 2 (ISR G2) family, the Cisco 867VAE Integrated Services Router offers connectivity to teleworkers and small branches.
- Cisco 867VAE - router - DSL modem - desktop, rack-mountable
- Router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop, rack-mountable - 1U
- Digital Signaling Protocol
- ADSL2+, VDSL2
- WAN Ports Qty
- 2
- Data Link Protocol
- Capacity
- IPSec VPN tunnels: 10
- IPSec, PPPoE, PPPoA, DHCP, DNS
- Routing Protocol
- RIP-1, RIP-2
- Remote Management Protocol
- SNMP 3, HTTP, HTTPS, SSH
- Firewall protection, auto-uplink (auto MDI/MDI-X), IPv6 support, LLQ, CBWFQ, WFQ, DHCP server, DNS proxy, DHCP relay, WSMA, NetFlow, DHCP client
- IEEE 802.1Q, IEEE 802.3ah
- Power
- AC 120/230 V (50/60 Hz)
- 20.9 cm x 19.8 cm x 3.9 cm
- 2.5 kg
- Router - 4-port switch (integrated)
- Enclosure Type
- Connectivity Technology
- Wired
- Capacity
- Routing Protocol
- RIP-1, RIP-2
- IEEE 802.1Q, IEEE 802.3ah, CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EN 61000-4-3, EN 61000-4-6, AS/NZS 3548, FCC CFR47 Part 15, VCCI V-3
- RAM
- 256 MB (installed) / 256 MB (max)
- Flash Memory
- 64 MB
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- ADSL2+, VDSL2
- Protocols & Specifications
- ITU G.994.1 (G.hs), ITU G.992.3 Annex A, ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.993.2, ITU G.992.3 Annex M, ITU G.992.5 Annex A, ITU G.992.5 Annex B, ITU G.992.3 Annex B
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x console - RJ-45 , WAN: 1 x ADSL2+ , USB: 1 x 4 pin USB Type A , WAN: 1 x VDSL2 , LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- External power adapter - 60 Watt
- Voltage Required
- OS Provided
- Cisco IOS Advanced Security
- 20.9 cm
- 19.8 cm
- 3.9 cm
- 2.5 kg
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
Cisco AC Power Cord (UK), C13, BS 1363, 2.5m | In Stock | £40.21 |
Cisco AC Power Cord | In Stock | £46.56 |
