Cisco 802.11N LOW-PROFILE OUTDOOR AP
Quicklinx: 9Z1DWS00 Mfr#: AIR-CAP1532E-E-K9
  • IEEE 802.11n
As carrier-grade Wi-Fi becomes a critical small-cell element in nextgeneration mobile networks, operators are requesting new access point designs that can pack a punch in a small form factor. The Cisco Aironet 1530 Series Outdoor Access Points incorporate a low-profile design that is esthetically pleasing, yet they can withstand the most rugged outdoor conditions. Cisco brings engineering innovation to the platform with unique Cisco Flexible Antenna Port technology that allows the same antenna ports to be used either for dual-band antennas to reduce the antenna footprint or for single-band antennas to optimize radio coverage. This flexibility allows antenna changes to be made on the fly, and saves on sparing costs. And the Cisco Aironet 1530 Series brings all the same robust Wi-Fi features that operators have come to expect from Cisco, including radio resource management, BandSelect to automatically take advantage of the 5-GHz band, and VideoStream for high-quality video performance over Wi-Fi. Only Cisco delivers all of these features in a hardened outdoor access point that is ideal for any urban setting.
The Cisco Aironet 1530 Series Outdoor Access Points are small enough and light enough to be unobtrusively mounted on street light poles or building facades.
The innovatively designed Cisco Aironet 1530E Outdoor Access Point is designed with antenna Cisco Flexible Antenna Port technology, which can support either dual-band or single-band antennas on the same platform and is configurable via software. When configured for dual-band ports, the Aironet 1530E uses the bottom two antenna ports to connect to dual-band omnidirectional or directional antennas. Alternatively, and for additional radio coverage flexibility, the Aironet 1530E can be software-configured, enabling two separate 2.4-GHz and two 5-GHz antenna ports. This flexibility allows customers to use high-gain directional antennas for backhaul on 5 GHz while deploying omnidirectional antennas for access on 2.4 GHz.
  • Sleek, innovative, flexible, proven
  • Compact, place-anywhere design
  • Innovative, external antenna
Cisco Aironet 1532E - radio access point - Wi-Fi
Radio access point
External - outdoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
26 cm x 17 cm x 10 cm
2.5 kg
1-year warranty
Radio access point
Ruggedized Design
Outdoor
26 cm
17 cm
10 cm
2.5 kg
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
CCK
Network / Transport Protocol
L2TP, IPSec
Frequency Band
2.4 GHz, 5 GHz
Selectable Channels Qty
13
MAC address filtering, DFS support, VPN passthrough, reset button, 2T2R MIMO technology, Cisco BandSelect technology, Cisco VideoStream technology
Encryption Algorithm
LEAP, AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2
Authentication Method
X.509 certificates
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, X.509, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
External detachable
1 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN) , 1 x management - RJ-45 , 4 x aerial
MIL-STD 810F, ANSI C62.41, EN 60950, ICES-003, IEC 60950, UL 60950, IEC 60529 IP67, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-5, FCC Part 15.107, FCC Part 15.109, AS/NZS 4268, FCC Part 15.407, ARIB STD-T66, ARIB STD-T71, CAN/CSA C22.2 No. 60950, EN 300 328, EN 301 489-1, EN 301 893, EN 301 489-17
PoE
25 Watt
Limited warranty - 1 year
-30 °C
65 °C
9Z1D C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
