Centralize your network operations on a powerful core that's capable of handling all your data and more. Formerly Linksys Business Series, now Cisco Small Business Managed Switches, the SGE2010P Ethernet Switch allows you to securely and reliably expand the size of your high-speed gigabit network. The SGE2010P maximizes network availability by incorporating redundant stacking and power capabilities. To reduce the number of cables needed for connected devices, this managed switch supports Power over Ethernet (PoE) and 15W of power for up to 24 ports. The integrated security and authorization features prevent unauthorized access to your network's critical information, and included Quality of Service (QoS) functionality bolsters your video and voice communications.
- Cisco Small Business Managed SGE2010P - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 (PoE) + 4 x shared SFP
- Power Over Ethernet (PoE)
- PoE
- MAC Address Table Size
- 8K entries
- Routing Protocol
- IGMPv2, IGMP
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH
- Auto-sensing per device, DHCP support, auto-negotiation, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, WRR queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, firmware upgradable, SNTP support, ACL support, QoS, Jumbo Frames support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 37.5 cm x 4.4 cm
- 4.9 kg
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- 8K entries
- Max Units In A Stack
- 4
- Routing Protocol
- IGMPv2, IGMP
- Encryption Algorithm
- MD5
- Authentication Method
- Secure Shell (SSH), RADIUS
- Status Indicators
- Port transmission speed, power, link OK, Unit ID, link/activity
- 48 x 1000Base-T RJ-45 PoE , 1 x console management , 4 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- Redundant Power System (RPS) connector
- Cables Included
- 1 x serial cable
- Rack Mounting Kit
- Included
- UL 60950, CSA C22.2, FCC CFR47 Part 15
- 44 cm
- 37.5 cm
- 4.4 cm
- 4.9 kg
- 0 °C
- 40 °C
- 10 - 90%
