The XJ-UT310WN's advanced LampFree light source combined with the Ultra-Short throw lens system produces 3100 lumens of brightness and boast WXGA (1280 x 800) resolution which is ideal for displaying HD content from video and computer sources. The 16:10 widescreen aspect ratio ensures your content is viewed without distortion.
The XJ-UT310WN boasts a full suite of inputs including, Video, Computer and HDMI terminals with audio. It is equipped with a powerful 16 watts speaker and a dedicated dynamic microphone input ensures everyone can hear. Network (RJ-45) and local RS-232 connections provide control and remote status monitoring capabilities while close captioning used in conjunction with Crestron RoomView allow direct email alerts and much more.
Ultra short throw lens
With its ultra-short throw lens the XJ-UT310WN can project brilliant, shadow-free images up to 110" diagonal. The built-in short throw lens and advanced mirror system provides an extremely close throw ratio (0.28:1) and enables you to project an 80" image from just 1.5 feet away. -
Brightness and resolution
The XJ-UT310WN's advanced LampFree light source combined with the Ultra-Short throw lens system produces 3100 lumens of brightness and boast WXGA (1280 x 800) resolution which is ideal for displaying HD content from video and computer sources. The 16:10 widescreen aspect ratio ensures your content is viewed without distortion. -
- Casio XJ-UT310WN - DLP projector - 3D - 802.11g/n wireless
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 3100 lumens
- Contrast Ratio
- 1800:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 16.7 million colours
- Bulb type
- Laser/LED
- Bulb life cycle
- Up to 20000 hour(s)
- Video Input
- RGB, S-Video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, PAL 60), IEEE 802.11g/n wireless - MPEG-4, AVI, MJPEG, H.264, MOV
- Storage Capacity
- 2 GB Flash
- Video Modes
- 1080p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 230 Watt
- 33.8 cm x 33.3 cm x 15.3 cm
- 5.5 kg
- 3D Capable
- Built-in Devices
- Speaker
- Networking
- 802.11b/g/n, Ethernet
Projector
- Brightness
- 3100 lumens
- Contrast Ratio
- 1800:1
- Image Size
- 127 cm - 279 cm
- Projection Distance
- 0.06 m
- Throw Ratio
- 0.28:1
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
- 16:10
- Display Format
- 1,024,000 pixels
- Colour Support
- Bulb type
- Laser/LED
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- JPEG photo playback, High-bandwidth Digital Content Protection System (HDCP), DLP 3D Ready, Hybrid Light Source, BMP photo playback, 4:3 aspect ratio support, Image Freeze Function, Ultra Short Throw Technology, Direct Power On, blank screen, PNG photo playback, AAC playback, GIF photo playback, USB Display, Intelligent Brightness Control, Eco Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.3
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -5/ +5
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- Video Modes
- 1080p
- Digital Video Format
- LAN and Wireless Image Transferring Protocols
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Media Player
- Storage Capacity
- 2 GB Flash
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x microphone - mini-phone mono 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management)
- Included Accessories
- USB wireless network adapter, 2 x AAA batteries, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Voltage Required
- 230 Watt
- Power Consumption Stand by
- 0.23 Watt
- 33.8 cm
- 33.3 cm
- 15.3 cm
- 5.5 kg
