Casio XJ-F210WN-UJ 3500 LM WXGA DLP-Chip Technology Projector
Quicklinx: C4DTWS00 Mfr#: XJ-F210WN-UJ
The innovative light source from CASIO not only offers exceptional projection performance - due to its low wear, it also manages to deliver this continuously high level of performance over a long period of time and even makes projections possible in daylight.
CASIO projectors and their exceptional light source are sure to amaze with their brilliant color reproduction and wide color range. This optical phenomenon causes the subjective perception of brightness to increase with the degree of color saturation. As a matter of fact, the CASIO projectors cover a larger part of the color spectrum visible to the human eye. Clear, vivid images with rich colors and the finest of nuances - an immersive experience for all involved. Thanks to the direct on/off function, CASIO projectors reach their full brightness after a maximum of five seconds - at just the push of a button. As a result, long waiting times and annoying warm-up and cool-down phases are a thing of the past - a fact that saves precious time. Lessons can start immediately and follow a more flexible structure, as the projector can be switched on quickly at any time.
  • A durable light source
    The actual power of the CASIO projectors lies deep within - the revolutionary laser and LED hybrid light source. This technology is the centerpiece of the projectors and functions without any need for quicksilver - in complete contrast to conventional projector lamps. The innovative light source from CASIO not only offers exceptional projection performance - due to its low wear, it also manages to deliver this continuously high level of performance over a long period of time and even makes projections possible in daylight.
  • Outstanding color rendition
  • Ready to start at the push of a button
    Thanks to the direct on/off function, CASIO projectors reach their full brightness after a maximum of five seconds - at just the push of a button. As a result, long waiting times and annoying warm-up and cool-down phases are a thing of the past - a fact that saves precious time. Lessons can start immediately and follow a more flexible structure, as the projector can be switched on quickly at any time. Set-up and clear-up times for business presentations are also made considerably shorter.
Casio Advanced XJ-F210WN - DLP projector - white
DLP projector
White
Built-in Devices
Speaker
Brightness
3500 ANSI lumens
Contrast Ratio
20000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB, S-Video, composite video, component video
Video Modes
480p, 1080p
Speakers
Speaker(s) - integrated
175 Watt
29.9 cm x 29.9 cm x 9.7 cm
3.5 kg
DLP projector
Built-in Devices
Speaker
Ethernet
Enclosure Colour
White
Projector
Brightness
3500 ANSI lumens
Contrast Ratio
20000:1
Image Size
89 cm - 762 cm
Projection Distance
0.92 m
Throw Ratio
1.32 - 1.93:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Keystone correction
Freeze frame, Direct Power On, Direct Power Off, blank screen, Presentation Timer, USB Viewer, Intelligent Brightness Control, rear projection, instant on/off
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.5x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
480p, 1080p
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x composite video input - RCA , 2 x HDMI input - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x USB - 5 pin Micro-USB Type B , 2 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A , 1 x microphone - mini-phone mono 3.5 mm , 1 x audio line-in - RCA x 2
2 x AAA batteries, remote control
1 x VGA cable
Security Features
Password protection
175 Watt
Power Consumption Stand by
0.23 Watt
29.9 cm
29.9 cm
9.7 cm
3.5 kg
5 °C
35 °C
Sound Emission
35 dB
