With the EOS 60D DSLR, Canon gives the photo enthusiast a powerful tool fostering creativity, with better image quality, more advanced features and automatic and in-camera technologies for ease-of-use. It features an improved APS-C sized 18.0 megapixel CMOS sensor for tremendous images, DIGIC 4 Image Processor for finer detail and excellent color reproduction, and improved ISO capabilities from 100 - 6400 (expandable to 12800) for uncompromised shooting even in the dimmest situations. The Multi-control Dial enables users to conveniently operate menus and enter settings with a simple touch. The EOS 60D also features an EOS first Vari-angle 3.0-inch Clear View LCD (1,040,000 dots) monitor for easy low- or high-angle viewing. An improved viewfinder, a number of in-camera creative options and filters, plus HDMI output for viewing images on an HDTV all make the EOS 60D invaluable for the evolving photographer. With continuously curved surfaces, user-friendliness and exuding solidity and refinement, the EOS 60D is true digital inspiration!
Exceptional quality images
The EOS 60D features Canon-designed 18.0 megapixel APS-C size CMOS sensor that captures such a high level of resolution, it's easy to crop images for enlargement without concern of losing detail. A major factor in reducing noise, the CMOS sensor assures that images shot at highest sensitivity will be remarkably smooth. The improved DIGIC 4 Image Processor ensures that images are captured, processed and saved with remarkable speed. The EOS 60D DSLR's 3:2 multiple aspect ratio, in-camera RAW image processing, creative filters, image resizing and provided S2 and S3 image-recording quality are all possible thanks to the DIGIC 4 Image Processor. With dazzling results, the DIGIC 4 Image Processor also works to capture and process data of images shot at 18.0 megapixels at 5.3 fps, as well as 14-bit signal processing for excellent image gradation, enhanced Face Detection Live mode, Full HD video recording, Auto Lighting Optimizer and Lens Peripheral Optimization. -
Excellence from dawn to dusk
With a broad range of ISO settings, expandable up to 12800 with Custom functions, the EOS 60D enables shooting from sunrise to sunset and helps ensure capture of the finest detail. With enhanced high-sensitivity optimization, subjects can be captured clearly and easily at high shutter speeds without flash, with minimized blur and noise. In bright scenes, especially long exposures in daylight, optimal exposure can be achieved with a fully open wide-diameter lens, no dark filter needed. -
Low angles or high, a big Vari-angle LCD captures the details
A first for any EOS, the EOS 60D features a bright, high resolution, flip-out Vari-angle 3.0-inch Clear View LCD monitor for shooting at a variety of angles. By easily switching between low and high angles, the EOS 60D freely enables angle adjustments even if the camera is mounted on a tripod or has a battery grip attached. With 1,040,000 (dots/VGA) pixels for spectacular detail, the advanced, smudge-resistant monitor includes high transparency materials plus anti-reflective and water-repellant coatings to provide clear and bright viewing. Superb for reviewing, editing and deleting photos or composing new images in Live View function, the Vari-angle Clear View LCD monitor is also the perfect means for accessing camera settings like ISO, metering modes, AF Point selection, the horizontal Electronic Level and flash options. -
The need for speed
The EOS 60D operates with such effortless speed that operation is nothing short of intuitive. With a 0.1 second start-up time, speedy autofocus and minimal shutter lag, the EOS 60D is made to capture even rapidly-occurring scenes with stunning precision. Able to shoot up to 5.3 frames per second (fps), capturing a maximum burst of approximately 58 Large/JPEGs and 16 RAW, the EOS 60D DSLR lets you catch even the briefest of moments, whether it's a faced-paced soccer game or the flicker of a candle flame. -
See more, get more
The EOS 60D features a phenomenally redesigned viewfinder that not only offers an improved 96% coverage, 0.95x magnification, a 27.0° angle of view and user-controlled dioptric adjustment, it also features a newly designed transparent LCD display that enables a number of viewfinder displays. A six-level battery check indicator has been added on the left, and the exposure level indicator scale has been expanded to up to three stops, with arrows indicating greater exposure levels. The EOS 60D also features an advanced horizontal Electronic Level, that, when activated, is superimposed on the LCD monitor to aid in achieving evenly leveled shots by indicating the horizontal tilt up to approximately 9° in 1° increments. -
Intelligent scene analysis for superb exposure
The EOS 60D features a sophisticated, 63-zone Dual-layer sensor designed to complement the 9-point AF system. By taking into account the color and luminosity surrounding chosen AF points, this system delivers an advanced level of accuracy for better results even in difficult lighting situations. Since the metering sensor has a color measurement function, exposure errors and focus errors caused by different light sources are minimized; the EOS 60D gives stable exposure from shot to shot in situations where light changes, such as in a theater or concert hall. This makes the EOS 60D ideal for scenes with extreme difference in brightness such as brightly lit scenes or backlit scenes; the camera balances exposure of the main subject at the background, and exposures are not overly influenced by bright areas in the shot. Since the EOS 60D provides high-speed X-sync ("X-sync" means the fastest shutter speed that can synchronize with a flash burst at the moment the shutter is fully released) up to 1/250 sec., the range of photographic expression is dramatically increased, allowing the EOS 60D to be used with confidence in bright scenes or dim. -
In-Camera technologies for an easier workflow
The EOS 60D marks a highpoint in convenience for the photographer by being able to shoot an image as a RAW file and then process it entirely in-camera to produce a separate JPEG file without the need of an outside computer. The EOS 60D gives you 10 process variables - brightness adjustment, white balance, Picture Style, Auto Lighting Optimizer, noise reduction, JPEG image-recording quality, color space, lens peripheral illumination correction, distortion correction and chromatic aberrations correction - to create the image you envision, set to the 3:2 aspect ratio used in 35mm film. Additionally, once you capture an image with the EOS 60D, you can digitally manipulate it in-camera with a number of creative filters for artistic and dramatic effect. Options include Soft Focus Effect to convey dreamy tableaus; Grainy Black-and-White Effect for a gritty, hard-bitten look; Toy Camera Effect - the deliberate vignetting and color shift technique popular in art photography - and Miniature Effect, which blurs the top and bottom edges of the image to emphasize perspective and conveys a miniaturized look of the scene. -
Flexible storage with memory cards
The EOS 60D DSLR uses popular SD, SDHC and SDXC memory cards. Compact, inexpensive and available in increasingly large capacities, SD, SDHC and SDXC memory cards are a perfect complement to the EOS 60D DSLR's compact and lightweight body design.
- Canon EOS 60D - digital camera - body only
- Product Type
- Digital camera - 1080p - SLR with Live View mode, movie recording
- Lens Included
- Body only
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 4
- Sensors
- Digital level metre
- Sensor Resolution
- 18.0 Megapixel
- Max Video Resolution
- 1920 x 1080
- Camera Flash
- Pop-up flash
- Viewfinder
- Optical - fixed eye-level pentaprism
- Display
- LCD display - 3"
- Supported Battery
- Canon LP-E6 Li-ion rechargeable battery (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Microsoft Certification
- Compatible with Windows 7
- 14.5 cm x 7.9 cm x 10.6 cm
- 0.68 kg
- Product Type
- Lens Included
- Body only
- Sensor Resolution
- 18.0 Megapixel
- Optical Sensor Type
- CMOS
- Total Pixels
- 19,000,000 pixels
- Effective Sensor Resolution
- 18,000,000 pixels
- Optical Sensor Size
- APS-C (22.3 x 14.9 mm)
- Field of View Crop Factor
- 1.6
- ISO (Max)
- 12800
- Sensor Dust Reduction
- Sensor Features
- EOS Integrated Cleaning System, Self Cleaning Sensor Unit
- Image Processor
- DIGIC 4
- Face Detection
- Sensors
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support
- Auto Focus
- TTL contrast and phase detection
- Auto Focus Points (Zones) Qty
- 9
- Digital Video Format
- MOV
- Image Recording Format
- JPEG, RAW, RAW + JPEG
- 1920 x 1080
- Interface
Exposure & White Balance
- Light Sensitivity
- ISO auto, ISO 12800, ISO 100-6400
- Exposure Metering
- Evaluative, partial (6.5%), multi-segment, centre-weighted, spot
- Exposure Metering Zones
- 63
- Exposure Modes
- Programme, bulb, automatic, manual, aperture-priority, shutter-priority, E-TTL II program flash
- Shooting Programs
- Landscape, portrait mode, close-up, night portrait, sports mode
- Special Effects
- Neutral, Custom Effect, Faithful, monochrome, landscape, portrait
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, tungsten light, Flash, daylight, shade
- Max Shutter Speed
- 1/8000 sec
- Min Shutter Speed
- 30 sec
- Exposure Compensation
- ±5 EV range, in 1/2 or 1/3 EV steps
- Auto Exposure Bracketing
- 3 steps in 1/2 or 1/3 EV steps
- White Balance Bracketing
- X-sync Speed
- 1/250sec
- Exposure Range
- EV 0-20 (ISO 100)
Lens System
- Lens Mounting Type
- Canon EF/EF-S
Camera Flash
- Camera Flash
- Pop-up flash
- Guide Number (m / ISO 100)
- 13
- Flash Modes
- Fill-in mode, E-TTL, rear curtain sync, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator, flash +/- compensation
Additional Features
- Continuous Shooting Speed
- 3 frames per second, 5.3 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Flash Terminal
- Hot shoe
- Additional Features
- RGB primary colour filter, digital noise reduction, depth-of-field preview button, camera orientation detection, histogram display, highlight tone priority, LCD live view mode, highlight point display, face detection, Auto Lighting Optimizer, in-camera RAW processing, peripheral illumination correction
Viewfinder
- Viewfinder Type
- Optical Viewfinder Field Coverage
- 96%
- Optical Viewfinder Magnification
- 0.95x
- Optical Viewfinder Dioptric Correction Range
- -3 to +1
- Viewfinder Information
- Shutter speed, AE lock, AF-in-focus, flash charge completion, red-eye reduction, aperture, white balance, battery status, high-speed sync indicator, flash compensation on/off, highlight tone priority, ISO sensitivity, memory card status, FE lock
Display
- 3" LCD display
- Display Format
- 1,040,000 pixels
- Display Form Factor
- Rotating
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- Composite video/audio output , USB , HDMI , Microphone
Software
- Software
- Drivers & Utilities, Canon PhotoStitch, Canon ZoomBrowser EX, Canon ImageBrowser, Canon Remote Capture, Canon Digital Photo Professional
- Included Accessories
- Battery charger, body cap, neck strap, USB cable, eyecup, audio / video cable
- Body Material
- Aluminium, fibreglass-reinforced polycarbonate resin
- Battery Type
- Canon LP-E6 Lithium Ion
- Details
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Image Storage
- RAW 5184 x 3456 , RAW 3888 x 2592 , RAW 2592 x 1728 , JPEG 5184 x 3456 , JPEG 3456 x 2304 , JPEG 2592 x 1728 , JPEG 1920 x 1280 , JPEG 720 x 480 , JPEG 4608 x 3456 , JPEG 3072 x 2304 , JPEG 2304 x 1728 , JPEG 1696 x 1280 , JPEG 640 x 480 , JPEG 5184 x 2912 , JPEG 3456 x 1944 , JPEG 2592 x 1456 , JPEG 1920 x 1080 , JPEG 720 x 400 , JPEG 3456 x 3456 , JPEG 2304 x 2304 , JPEG 1728 x 1728 , JPEG 1280 x 1280 , JPEG 480 x 480
- Video Capture
- MOV - 1920 x 1080 - 30 fps , MOV - 1920 x 1080 - 25 fps , MOV - 1920 x 1080 - 24 fps , MOV - 1280 x 720 - 60 fps , MOV - 1280 x 720 - 50 fps , MOV - 640 x 480 - 60 fps , MOV - 640 x 480 - 50 fps , MOV - 640 x 480 - 30 fps , MOV - 640 x 480 - 24 fps
- 14.5 cm
- 7.9 cm
- 10.6 cm
- 0.68 kg
- 0 °C
- 40 °C
