Best Value Alpine 700W PSU 120mm Blue Fan
Quicklinx: 9TRLWS00 Mfr#: ALPINE-BLUE-700W
  • Cable length 45cm
  • Meets Intel v2.03 enhanced +12V
  • 230V with rear on/off power down button
  • Over-voltage and current protection +3.3V;+5V;+12V
  • 100% Burn in and hipot tested; short circuit protection
  • EMI Filter built in
  • CE/ FCC/ UL approved
  • ROHS Compliant
  • +3.3V 24A; +5V 34A; +12V 38A; -12V 0.5A; +5VSB 2.0A
  • Silent 120mm blue fan with low noise technology <20dBA
  • Packaged in designer retail box
  • Quiet fan with thermal control
  • Black coated casing
  • 24 pin; 4 Pin (12V); 1 x 6 pin PCI-e; 4 x Sata; 3 x 4 pin; 1 x FDD
