Featuring a 1.6x big zoom, lens shift and keystone correction, the MX764 gives you an impressively wide range of projector installation and placement flexibility. This XGA projector also offers 4200 ANSI lumen ultra-high brightness, 5300:1 ultra-high contrast ratio and 20W big built-in speaker.
XGA native resolution
The MX764 boasts a XGA native resolution, delivering crisp and accurate images every time to keep your presentation looking great. -
4200 ANSI lumens
Built to fit your projection needs for medium to large-sized venues, the MX764 brightens your presentation with 4200 ANSI lumen high brightness. Now, you can intrigue your audience with clearer, more vivid pictures even in environments impractical to block out extraneous light. -
The MX764 boasts an ultra-high contrast ratio of 5300:1, defining images with razor-sharp details and refining them with a broad range of subtle color differences. What's more, with a contrast ratio this high, text is sharper, cleaner and easier to read. -
1.6x big zoom ratio
The MX764 comes featuring a 1.6x big zoom ratio, offering a real wide range of throw distance ranging from 1.07 to 2.72 meters. The added flexibility makes it easier for installing new projectors in venues without the trouble of reconstruction. -
Manual vertical lens shift
This function allows you to make minor projection adjustments to the projected image by shifting the image up by 20°. This gives you the extra flexibility to overcome slight miscalculations during a new projector installation. -
Auto/manual keystone ± 40 degrees
The MX764 allows you to get rid of misshaped images, graphics and charts instantaneously via its ± 40° vertical keystone adjustment function. With the MX764, a perfect square is all you'll see! -
Built-in 20W big audio power
The MX764 features two built-in 10W speakers to help enrich your presentation with top quality audio performances. These speakers are sealed and secured within the projector housing by BenQ's anti-shake design to ensure projection stability at all times. -
Microphone input support
With the microphone input, you will no longer need to shout at the top of your lungs to get the attention of your audience. All you need to do is plug in the microphone or microphone headset to get your point across! -
Audio in/out
With the built-in speakers, the MX764 can be used as an audio system when it's on the standby mode. This saves you the trouble as well as the extra budget for getting a separate audio system. -
PC-less presentation with USB reader and remote desktop
The MX764 supports PC-less presentation in two ways: USB reader and remote desktop. You can either give your presentation directly from the presentation files saved onto a USB flash drive or remotely by accessing their computer using a wireless mouse and keyboard through LAN. Either way, you won't have to carry your laptop around or require a PC stationed in every room. -
Plug 'n play with USB display
The USB display feature gives you ultra-smooth, signal decay-free audiovisual projection with a simple plug 'n play. All you need is a USB cable to connect your computer to the MX764 to give your audience the best viewing experience. This feature also enables simultaneous projection from one display source. -
Wired and wireless LAN display
LAN display helps IT managers implement projector management to control and display classroom projections, as well as transmit audio signals, through various display options. It also comes with simultaneous school-wide emergency broadcast capability. The MX764 enables LAN display through a single LAN cable as well as a wireless display adapter. -
LAN control with crestron and PJ-Link
LAN control is designed to help IT managers perform day-to-day projector maintenance and repair tasks efficiently and effectively-offering them full access and control over every projector directly from their workstations. The MX764 offers seamless support for the crestron and PJ-Link LAN control system.
- BenQ MX764 - DLP projector - 3D - LAN
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Stereo speakers
- Brightness
- 4200 lumens
- Contrast Ratio
- 5300:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Lens Shift Direction
- Vertical
- Bulb type
- 300 Watt
- Bulb life cycle
- Up to 2000 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL), LAN
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 406 Watt
- 33.9 cm x 23.8 cm x 12.05 cm
- 3.3 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Stereo speakers
Projector
- Brightness
- 4200 lumens
- Contrast Ratio
- 5300:1
- Image Size
- 101.6 cm - 762 cm
- Throw Ratio
- 1.4 - 2.24:1
- Digital Zoom Factor
- 2x
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- 300 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
- sRGB colour profile, freeze frame, Closed Caption, wall colour correction, BrilliantColor, USB host function, DLP 3D Ready, Wireless Ready, PJlink, 3D Color Management, blank screen, ecoFACTS, Display over USB (DoUSB), Auto Power Off, Presentation Timer, Digital Zoom
Lens
- Lens Aperture
- F/2.45-3.07
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
- Lens Shift Type
- Manual
- Vertical
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 Watt
- Speakers
- 2 x right / left channel
Input Device
- External
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 2 x USB - 4 pin USB Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x USB - mini-USB Type B , 1 x audio line-out - mini-phone stereo 3.5 mm , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone input - mini-phone 3.5 mm
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Plug and Play
- Voltage Required
- 406 Watt
- Power Consumption Operational (Standby)
- 0.5 Watt
- 33.9 cm
- 23.8 cm
- 12.05 cm
- 3.3 kg
- Limited warranty - lamp - 1 year / 2000 hours
- Sound Emission
- 35 dB
- Sound Emission (Economic Mode)
- 30 dB
