BenQ EX3203R 31.5" 2560 x 1440  4ms HDMI LED Monitor Curved
Quicklinx: G387WS00 Mfr#: 9H.LGWLA.TSE
Diagonal Size: 31.5in
Max Resolution: 2560 x 1440
Response Time: 4ms
Interfaces: DisplayPort, USB-C, HDMI
£407.36 ex VAT
£488.83 inc VAT
EX3203R's 32" captures your attention and fills your field of vision. And the 1800R curvature is the ideal curve ratio for an immersive viewing experience.
  • Big screen size and curvature ratio for immersive gaming
  • QHD resolution delivers image of clarity and vividity
    Near twice pixel density than FHD, QHD 2560x1440 resolution can reveal the details of the image in crisp clarity and sharpness to enhance your gaming enjoyment.
  • Ultra-slim bezel edge-to-edge design for an expansive view
    Incorporating ultra-slim bezels with edge-to-edge panels, you can connect multiple EX3203R to set up a seamless vision with limitless perspective.
  • HDR support for enhanced image
    Featuring the leading HDR technology in a gaming entertainment monitor, EX3203R delivers incredible image performance of vividity with enhanced brightness and contrast.
  • FreeSync 2 for smoother gaming
    FreeSync 2 technology offers supremely smooth gaming experience with the enhanced support of HDR contents. Gamers can fully enjoy the sharpened details and clarity of the HDR games and fluid gaming enjoyment without image tearing, broken frames, and choppy gameplay. And with 144 Hz high refresh rate, EX3203R brings out an ultra-smooth gaming experience.
  • One cable to simplify all connections
    Adopting the USB-C architecture, EX3203R carries high-resolution video and audio, and SuperSpeed data transfers on a single compact and reversible connection.
  • Universal multi-platform connectivity
    Comprehensively equipped with multiple HDMI, DisplayPort, and USB 3.1 ports in addition to USB-C, EX3203R expertly hosts multimedia content from a variety of source devices ranging from set-top boxes, Blu-rays, gaming consoles, and smart devices.
  • Brightness Intelligence Plus technology
    BenQ's unique Brightness Intelligence Plus technology brilliantly detects ambient light levels and the color temperature in your viewing environment to automatically adjust on-screen brightness and color temperature for your viewing comfort. Your contents on the screen don't get overexposed while enhancing details in dark areas to maintain a visible level of clarity and intensity.
  • Low Blue Light technology
    Proprietary BenQ Low Blue Light technology filters out hazardous blue light, effectively reducing eye fatigue and irritation and bringing viewing comfort.
  • Flicker-free technology
    Exclusive BenQ Flicker-free technology eliminates the harmful flicker of traditional LCDs to prevent fatigue and vision damage.
BenQ EX3203R - LED monitor - curved - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class G
Energy Consumption per Year
94 kWh
Power Consumption (On mode)
39.8 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync, AMD FreeSync Premium Pro
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 144 Hz
Pixel Pitch
0.272 mm
Brightness
400 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
90% DCI-P3
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Height, tilt
Voltage
AC 90 - 264 V (50/60 Hz)
Grey
71.269 cm x 22.387 cm x 53.6 cm
8.1 kg
HDCP 2.2
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
94 kWh
Diagonal Size
31.5"
Curved Screen
Yes (1800R)
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
90% DCI-P3
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
45 - 144 Hz
Horizontal Refresh Rate
30 - 167 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Hungarian, Czech, Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Romanian, Japanese, Chinese, Korean, Serbo-Croatian
Picture in picture, Advanced Motion Accelerator (AMA) technology, SUPER Resolution, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, PBP, Brightness Intelligence Plus Technology
Grey
8.1 kg
2 x HDMI , DisplayPort , 2 x USB 3.1 Gen 1 , Headphones , USB-C
Mechanical
Height, tilt
Tilt Angle
-5/+20
Height Adjustment
60 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), on/off switch
1 x HDMI cable
HDCP 2.2
Security Slot Type
Kensington security slot
Input Voltage
39.8 W
39.8 kWh/1000h
Power Consumption HDR (On mode)
61.3 kWh/1000h
Power Consumption (Typical)
100 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - pick-up and return - 2 years
5 °C
20 - 90%
Response Time: 4ms
Interfaces: USB-C
Interfaces: HDMI
Brand: BenQ
