BenQ BL2283 21.5" 1920 x 1080 5ms HD LED Monitor
Quicklinx: FBPDWS00 Mfr#: 9H.LHSLA.TBE
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15), HDMI
£120.80 ex VAT
£144.96 inc VAT
Designed for beautiful simplicity, BenQ's BL2283 21.5" frameless monitor combines ultra slim bezels with hidden cable management. Complementing BenQ's exclusive Eye-Care Technology with Low Blue Light Technology and Flicker-Free performance for extended viewing comfort, the industry-leading Brightness Intelligence Technology delivers exquisite details in any ambient lighting environment. Built with the dream combination of LED with IPS panel, BL2283 is bound to bring a whole new visual experience and enjoyment to you with truly authentic colors, deeper blacks, higher contrast and sharper details.
  • Understated, stylish and sophisticated design
    BL2283 comes with a stylish and sophisticated design that boasts an elevated level of elegance while helping to enhance the overall productivity. Empowered by the premium etching texture and sculpted base, BL2283 resists fine scratch whirls and eliminates extraneous edges for a clean, functional appeal. Additionally, the edge-to-edge panel with ultra slim bezels can complement any modern décor. To ensure the cleanest look, BL2283 offers an invisible cable management system to neatly hide all wires inside the monitor's stand.
  • IPS wide-viewing-angle technology
    IPS (In-Plane Switching) technology provides accurate color and image reproduction from any angle. An expansive 178° viewing angle is ideal for work and for on-screen reviews with multiple people in the room.
  • 8-bit color display
    With the ability to render 16.7 million color shades simultaneously, you can expect true colors, silky transitions and impeccable image quality.
  • BenQ's exclusive eye-vare technology
    BenQ's exclusive eye-care technologies reduce eye fatigue for user comfort, enhanced productivity, and workplace safety during extended use.
BenQ BL2283 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class F
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
17.7 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
48.95 cm x 18.3 cm x 39.16 cm
2.9 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
TUV Rheinland, HDCP 1.4
Display Type
Energy Class
Class F
28 kWh
Diagonal Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Advanced Motion Accelerator (AMA) technology, Low Blue Light Mode, Flicker Free technology, Ultra Slim Design Bezel, Eye-Care Technology, Brightness Intelligence Technology, 72% NTSC colour gamut
2.9 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , 2 x HDMI , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Input Voltage
AC 120/230 V
17.7 W
17.7 kWh/1000h
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.5 Watt
Shipping Weight
3.7 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.0
Response Time: 5ms
Interfaces: HDMI
Brand: BenQ
