Your basket is empty
Belkin Surf Wireless N150 BT ADSL Modem Router
Belkin Surf Wireless N150 ADSL Modem Router
Quicklinx: 6P5WWS00 Mfr#: F7D1401UK
  • IEEE 802.11b
Good speed and coverage, with a range that easily covers your small home or apartment. Belkin's Surf routers are aimed at people wanting to surf the web from anywhere in their home, but have been put off by traditional routers' over-complicated installation. Get your secure wireless network up and running in minutes. Just three easy steps, and you're up and running out of the box and onto the Web.
Belkin Surf Wireless Modem Router - wireless router - DSL - 802.11b/g/n - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, PPPoE
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP, HTTPS
Dynamic IP address assignment , NAT support, VPN support, Stateful Packet Inspection (SPI), MIMO technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPSec passthrough
IEEE 802.11b, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n
Environmental Standards
ENERGY STAR Qualified
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 - 10.6
United Kingdom
2 years warranty
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Static IP routing
HTTP, HTTPS
Encryption Algorithm
128-bit WEP, 64-bit WEP, 256-bit WPA, WPA2, WPA-PSK
Authentication Method
Radio Service Set ID (SSID)
Status Indicators
Status
Communications
DSL modem
ADSL
LAN : 4 x 10Base-T/100Base-TX - RJ-45 , WAN : 1 x ADSL
Aerial
Aerial
Internal integrated
Power adapter - external
Plug and Play
United Kingdom
Software Included
Drivers & Utilities, Self-Healing
2 years warranty
Service & Support Details
10 - 85%
