Belkin Play Max Wireless Router doubles your performance and bandwidth with Dual-Band N technology. Simultaneous networks eliminate interference and optimize media-intensive applications like videos and gaming. Dual-plane antennas and MIMO technology provide three-dimensional whole-home coverage for consistent signal, even through walls and floors. WPS/WPA2 encryption standards and preset security settings get you up and running safely. One-touch Wi-Fi Protected Setup (WPS) securely connects multiple computers and devices with the push of a button.
Performance
Get maximum speed and performance for media-intensive applications -
Speed
Double your performance and bandwidth with Dual-Band N technology. Simultaneous networks eliminate interference and optimize media-intensive applications like videos and gaming. -
3D coverage
Dual-plane antennas and MIMO technology provide three-dimensional whole-home coverage for consistent signal, even through walls and floors. -
Security
WPS/WPA2 encryption standards and preset security settings get you up and running safely. One-touch Wi-Fi Protected Setup (WPS) securely connects multiple computers and devices with the push of a button. -
Video max HD
Dual-Band optimizes multiple media files like streaming HD video and games. -
Easy setup
Get your secure wireless network up and running in minutes. Just 3 easy steps, and you're you out of the box and onto the web. -
Downloading made easy
Don't wait around for large torrent downloads like movies, music and games. The torrent genie app lets you continue downloading even if your computer is shut down or asleep. When you come back, your large media files will be fully downloaded and ready to enjoy. -
Show your music how to move
The music mover app lets you play MP3s from your music library on your home stereo - wirelessly. Connect your external hard drive where you store your music to the router - and move music from your computer to your stereo through devices like Xbox 360 and PlayStation 3. -
Mix it up
Not sure what to listen to? Let the daily DJ app serve up daily personalized playlists from your music library. Analyzing the musical DNA of your music, the app lets you select one of three mood mixes: high-energy, steady groove or kick back. Or create your own playlist by choosing a song and letting daily DJ offer a new take on your favorite music. -
Keep track of your tracks
Is your music library cluttered with unidentified tracks? The music labeler app automatically scans over 40 million songs from the Internet database and matches your track with the correct title, artist and genre. Rock on. -
Print from anywhere in the house
Printing has never been easier. Just connect any compatible printer to your Belkin router, and the print genie app lets you print from any computer on the network, from anywhere in your home - wirelessly. -
Protect your precious memories
Digital files are time-consuming to keep track of and vulnerable to loss. The memory safe app automatically backs up precious photos and important files to an external hard drive attached to the router - you choose what to back up and how often, and memory safe makes sure it's protected. -
The network that takes care of itself
The self-healing app automatically detects and resolves network problems and runs routine maintenance scans to give you the clearest wireless channel. If attention is required, a notification will appear right on your screen - no more blinking lights under your desk.
- Belkin F7D4301 - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Data Transfer Rate
- 300 Mbps
- TCP/IP, PPTP, L2TP, IPSec, PPPoE
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- HTTP, HTTPS
- Dynamic IP address assignment, NAT support, VPN support, SPI, MIMO technology, WPS, IPSec passthrough
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Environmental Standards
- ENERGY STAR Qualified
- Microsoft Certification
- Compatible with Windows 7
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.6, Microsoft Windows 7 64-bit Edition, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits)
- Localisation
- United Kingdom
- 2-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- 300 Mbps
- Routing Protocol
- Static IP routing
- HTTP, HTTPS
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 256-bit WPA, WPA2
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Plug and Play
- Status Indicators
- Status
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- ENERGY STAR Certified
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities, Print Genie, Self-Healing, Memory Safe, Music Mover, Daily DJ, Music Labeler, Torrent Genie
- OS Required
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 5 - 95%
