AXIS M1011-W Network Camera is perfectly suited for securing small businesses, boutiques, restaurants, hotels or residences. The camera offers both wireless (IEEE 802.11g) and wired connection to the network for flexible installation. It offers superior video quality in its class at 30 frames per second in VGA resolution.
AXIS M1011-W provides multiple, individually configurable video streams in H.264 as well as motion JPEG and MPEG-4 Part 2. Full frame rate and resolution is provided in either compression. The H.264 compression enables optimization for bandwidth and storage efficiency by significantly reducing the bit rate.
Small and functional camera design
AXIS M1011-W Network Camera is perfectly suited for securing small businesses, boutiques, restaurants, hotels or residences. The camera offers both wireless (IEEE 802.11g) and wired connection to the network for flexible installation. It offers superior video quality in its class at 30 frames per second in VGA resolution. -
High-performance compression and streaming capabilities
- AXIS M1011-W Network Camera - network surveillance camera
- Network surveillance camera - fixed
- 5.9 cm x 3.4 cm x 9.5 cm
- 94 g
- Connectivity Technology
- Wired, wireless
- Camera
- Max Resolution
- 640 x 480
- Optical Sensor Type
- CMOS - 1/4"
- Minimum Illumination
- 1 lux F2.0
- Focal Length
- 4.4 mm
- Lens Iris
- Fixed iris
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g
- Voltage
- DC 5 V
- Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, brightness control, contrast control
- Environmental Parameters (operating)
- 0 °C - 50 °C; 20 - 80% relative humidity
- Wired, wireless
- 5.9 cm
- 3.4 cm
- 9.5 cm
- 94 g
- Localisation
- United Kingdom
Camera
- Colour - fixed
- Digital Video Format
- MPEG-4, MJPEG, H.264
- Max Digital Video Resolution
- 640 x 480
- Exposure Range
- 1/5000 sec - 1/4 sec
- 1 lux F2.0
- Video Capture
- 640 x 480 @ 30 fps , 160 x 120 @ 30 fps
- RAM
- 64 MB
- Flash Memory
- 32 MB
Image Sensor
- CMOS 1/4"
Lens Construction
- Focal Length
- 4.4 mm
- Lens Iris
- Fixed iris
- Horizontal Field of View (degree)
- 47
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, HTTP over SSL, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, Bonjour, RTCP, IGMP
- Interfaces Details
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
- Included Accessories
- Stand
- C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, RSS-210, CCC, EN 60950-1, TELEC, EN 300 328, EN 301 489-1, EN 301 489-17
- Power Requirements
- DC 5 V
- Power Device
- Power adapter - external
- Software Included
- Drivers & Utilities
- 0 °C
- 50 °C
- Relative Humidity (operating)
- 20 - 80%
