AXIS Q6032-E is an outdoor-ready PTZ dome network camera for cost-efficient and reliable installation in demanding surveillance applications. It is ideal for use at airports and seaports, as well as for city and perimeter surveillance. The camera is powered through high power over Ethernet. This simplifies installation since only one cable is needed.
Arctic temperature control allows the camera to not only function at -40°C but also power up at that temperature following a power failure. AXIS Q6032-E can operate in temperatures from -40°C to 50°C. It has an IP66-rated protection against dust and water.
AXIS Q6032-E has a fast and precise pan/tilt response. In addition, it can tilt 20° above the horizon for a total tilt range of 220°, enabling better views, especially over uneven terrain. It has 35x optical and 12x digital zoom. The camera has an auto-tracking functionality that can automatically detect and follow a moving object within the camera's field of view.
Demanding outdoor video surveillance
AXIS Q6032-E is an outdoor-ready PTZ dome network camera for cost-efficient and reliable installation in demanding surveillance applications. It is ideal for use at airports and seaports, as well as for city and perimeter surveillance. The camera is powered through high power over Ethernet. This simplifies installation since only one cable is needed. -
Reliable operation in extreme climates
Arctic temperature control allows the camera to not only function at -40°C but also power up at that temperature following a power failure. AXIS Q6032-E can operate in temperatures from -40°C to 50°C. It has an IP66-rated protection against dust and water. -
Precise pan/tilt performance and high zoom
- AXIS Q6032-E PTZ Dome Network Camera - network surveillance camera - dome
- Network surveillance camera - fixed - dome - dustproof / waterproof
- 23.2 cm x 23.2 cm x 26.8 cm
- 3.5 kg
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night - NTSC
- Optical Zoom
- 35 x
- Max Resolution
- 704 x 480
- Optical Sensor Type
- EXview HAD CCD - 1/4"
- Focal Length
- 3.4 mm - 119 mm
- Focus Adjustment
- Automatic
- Lens Iris
- F/1.4-4.2
- Panning Range (degree)
- 360
- Tilting Range (degree)
- 220
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Motion sensor, sharpness control, colour control, alarm function, progressive scanning, adaptive lighting, image stabilizer, SD-card slot, brightness control, Power over Ethernet, contrast control, e-mail alerts, image flip
- 3-year warranty
- Environmental Parameters (operating)
- -40 °C - 50 °C; 0 - 93% relative humidity
- Form Factor
- Dome
- Wired
- 23.2 cm
- 23.2 cm
- 26.8 cm
- 3.5 kg
- Localisation
- Europe
Camera
- Colour - Day&Night - fixed - dustproof / waterproof
- Video Format
- NTSC
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 704 x 480
- Digital Zoom
- 12
- Exposure Range
- 1/2 sec - 1/30000 sec
- Video Capture
- 704 x 480 @ 30 fps , 176 x 120 @ 30 fps
- RAM
- 128 MB
- Flash Memory
- 128 MB
Image Sensor
- EXview HAD CCD 1/4"
Lens Construction
- Optical Zoom
- 35 x
- Focal Length
- 3.4 mm - 119 mm
- Lens Iris
- F/1.4-4.2
- Focus Adjustment
- Automatic
- Horizontal Field of View (degree)
- 1.7 - 55.8
Panning
- Range (degree)
- 360
- Speed (degree/sec)
- Up to 450
Tilting
- Range (degree)
- 220
- Up to 450
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, HTTP over SSL, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, UPnP, Bonjour, RTCP, IGMP
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
- Included Accessories
- Clear and smoked domes, sunshield
- UL, C-Tick, VCCI Class B ITE, cUL, EN 61000-3-2, GS, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 61000-6-2, EN 60950-1
- Power Requirements
- PoE
- Power Device
- Power injector - external
- Software Included
- Drivers & Utilities
- OS Required
- Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Microsoft Windows Vista
- Limited warranty - 3 years
- -40 °C
- 50 °C
- Relative Humidity (operating)
- 0 - 93%
