AXIS M1113 network camera with CS-mount, varifocal, DC-iris lens provides excellent image quality without motion blur using progressive scan at 30 frames per second in SVGA resolution. The cost-effective, compactly designed camera offers multiple H.264 and Motion JPEG streams that can be individually optimized for bandwidth and storage efficiency. It features Power over Ethernet, digital PTZ and a pixel counter to verify that the required pixel resolution is met. Intelligent video functionalities include video motion detection and active tampering alarm. AXIS M1113 is ideal for securing stores, malls, schools, banks and other office buildings, indoors as well as in an outdoor housing.
Excellent image quality with progressive scan
The AXIS M1113 with CS-mount, varifocal, DC-iris lens provides excellent image quality without motion blur using progressive scan at 30 frames per second in SVGA resolution. Multiple H.264 streams, as well as motion JPEG streams, can be provided either in full frame rate or individually optimized for different quality needs and bandwidth constraints. -
Power over Ethernet
Power over Ethernet supplies power to the camera via the network, eliminating the need for power cables and reducing installation costs. The pixel counter further helps the installer verify that the pixel resolution of an object or face fulfills regulatory or specific customer requirements, for example, for facial identification purposes. -
Digital pan/tilt/zoom
The AXIS M1113 supports digital pan/tilt/zoom, which allows a view cropped from the full view to be streamed for viewing or recording.
- AXIS M1113 Network Camera - network surveillance camera
- Network surveillance camera - fixed
- 6.1 cm x 9.4 cm x 4.3 cm
- 200 g
- Connectivity Technology
- Wired
- Camera
- Optical Zoom
- 2.8 x
- Max Resolution
- 800 x 600
- Optical Sensor Type
- CMOS - 1/4"
- Minimum Illumination
- 0.6 lux F1.4
- Focal Length Control
- Vari-focal
- Focal Length
- 2.9 mm - 8.2 mm
- Lens Mounting
- CS-mount
- Lens Iris
- Auto iris (DC)
- Ethernet 10Base-T/100Base-TX
- Voltage
- PoE
- Backlight Compensation (BLC), sharpness control, digital image rotation, white balance, colour control, progressive scanning, brightness control, contrast control
- 1-year warranty
- Environmental Parameters (operating)
- -20 °C - 50 °C; 20 - 80% relative humidity
- Wired
- 6.1 cm
- 9.4 cm
- 4.3 cm
- 200 g
Camera
- Colour - fixed
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 800 x 600
- Exposure Range
- 1/24500 sec - 1/6 sec
- 0.6 lux F1.4
- Video Capture
- 800 x 600 @ 30 fps
- RAM
- 128 MB
- Flash Memory
- 128 MB
Image Sensor
- CMOS 1/4"
Lens Construction
- CS-mount - vari-focal
- Optical Zoom
- 2.8 x
- Focal Length
- 2.9 mm - 8.2 mm
- Lens Iris
- Auto iris (DC)
- Horizontal Field of View (degree)
- 25 - 65
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, SOCKS, RTSP, RTP, HTTPS, UPnP, Bonjour, RTCP, IGMP
- Interfaces Details
- 1 x network / power - Ethernet 10Base-T/100Base-TX - RJ-45
- Included Accessories
- Stand
- C-Tick, VCCI Class B ITE, EN 61000-3-2, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 60950-1, EN 61000-6-3
- Power Requirements
- PoE
- Software Included
- Drivers & Utilities
- Limited warranty - 1 year
- -20 °C
- 50 °C
- Relative Humidity (operating)
- 20 - 80%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.52 |
