Aruba 2930M 24G PoE+ with 1-slot Switch
Quicklinx: FBKJWS00 Mfr#: JL320A
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
POE: PoE+
26 In Stock
£1,219.33 ex VAT
£1,463.19 inc VAT
The Aruba 2930M Switch Series is designed for digital workplaces optimized for mobile users. These Layer 3 access switches are easy to deploy and manage with advanced security and network management tools like Aruba ClearPass Policy Manager, Aruba AirWave and cloud-based Aruba Central. Modular stacking, uplinks and power provide scalability and simplicity for enterprise edge, SMB and branch offices. The 2930M delivers performance and value with support for static, RIP and Access OSPF routing, 10GbE and 40GbE uplinks, models with 24 ports of HPE Smart Rate multi-gigabit Ethernet, up to 1440W of PoE+, robust QoS, SDN and requires no software licensing.
  • High-Performance Layer 3 Access Switches
    The Aruba 2930M Switch Series provides performance, security, and ease of use for enterprise edge, SMB, and branch office networks.Optimized for the digital workplace with unified management tools such as Aruba ClearPass Policy Manager, Aruba Airwave and Aruba Central. Provides optimal configuration automatically when connected to Aruba access points for PoE priority, VLAN configuration, and rogue AP containment.Pay as you grow modular stacking (10 chassis) and modular 10GbE (SFP+) and 40GbE (QSFP+) uplinks. HPE Smart Rate multi-gigabit Ethernet models support high speed APs over existing cabling and upgradeable power supplies allow your network to quickly scale when more PoE+ is needed.Robust Layer 3 feature set includes Access OSPF, static and RIP routing, ACLs, Tunnel Node, sFlow, IPv6 with no software licensing required.Designed with a power ProVision ASIC, the 2930M supports multiple programmatic interfaces, including REST APIs and Openflow 1.0 and 1.3, to enable automation of network operations, monitoring, and troubleshooting.
  • Performance and Power at the Edge
    The Aruba 2930M Switch Series is designed with a powerful Aruba ProVision ASIC, to enable the mobile campus with low latency, increased packet buffering, and adaptive power consumption.Increase performance with selectable queue configurations and associated memory buffering that meets your specific network application requirements.Plug and play with up to 10 chassis stacking allowing automated failover enhances network resiliency and RPS support delivers power redundancy.Supports up to 740W of internal PoE+ power for wireless access points, cameras and phones and can easily scale to 1440W with choice of power supplies.
  • Security and Quality of Service You Can Rely On
    The Aruba 2930M Switch Series includes security and quality of services (QoS) features to build a network that meets ever-changing corporate policies and compliances while protecting your data from both inside and outside attacks.Flexible authentication options include standards based security protocols such as 802.1X, MAC and Web Authentication, to enhance security and policy-driven application authentication.Powerful multilevel-access security controls include source-port filtering, RADIUS/TACACS+, SSL, port security, and MAC address lockout.Tunneled Node to transport network traffic on a per-port basis to the Aruba controller delivering authentication and network policies applied and enforced at the controller.
  • Simplify with Integrated Wired/Wireless Management
    The Aruba 2930M Switch Series supports Aruba ClearPass Policy Manager for unified and consistent policy between wired and wireless users and simplifies implementation and management of guest login, user onboarding, network access, security, QoS, and other network policies.Aruba Airwave Network Management software provides an on-premise network management platform for wired and wireless network devices. Cloud-based management with Zero Touch Provisioning supported by Aruba Central.Supports both cloud-based Central and on-premise AirWave with the same hardware ensuring change of management platform without ripping and replacing switching infrastructure.RMON and sFlow provide advanced monitoring and reporting capabilities for statistics, history, alarms and events.Out-of-band Ethernet management port keeps management traffic segmented from your network data traffic.
HPE Aruba 2930M 24G POE+ 1-Slot - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
20 x 10/100/1000 (PoE+) + 4 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
720 W
Performance
Throughput: 95.2 Mpps , Switching capacity: 128 Gbps , Latency (1 Gbps): 3.1 µs , Latency (10 Gbps): 3.4 µs , Latency (10 Mbps): 98.5 µs , Latency (100 Mbps): 11.8 µs
IPv4 routing table entries: 2000 , IPv6 routing table entries: 1000 , RIP routes: 10000 , Static routes: 256
MAC Address Table Size
32768 entries
Jumbo Frame Support
9220 bytes
Routing Protocol
OSPF, RIP, RIP-1, RIP-2, IGMPv2, IGMP, OSPFv2, static IP routing, IGMPv3, OSPFv3, static IPv4 routing, static IPv6 routing, ECMP, RIPng, MLD, CIDR
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, SNMP, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, SSH-2, CLI, XRMON
Flow control, full duplex capability, DHCP support, BOOTP support, ARP support, VLAN support, IGMP snooping, Syslog support, DiffServ support, IPv6 support, SNTP support, sFlow, STP support, MSTP support, ACL support, QoS, Jumbo Frames support, DHCP server, MLD snooping, STP Root Guard, UDLD, LLDP support, LACP, MIB, MAC address lockout, dynamic ARP protection, DHCP protection, GVRP, MVRP, NDP, CoS, ToS, OpenFlow support, CPU protection, ICMP, ICMP Router Discovery Protocol (IRDP), VXLAN, MIB II, LLDP-MED, STP BPDU Guard
IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.1AX, IEEE 802.3bz
AC 120/230 V (50/60 Hz) - power supply not installed
44.25 cm x 32.43 cm x 4.39 cm
4.5 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
720 W
Performance
32768 entries
Jumbo Frame Support
9220 bytes
Routing Protocol
Encryption Algorithm
MD5, SSL, TLS
Authentication Method
RADIUS, PAP, CHAP, TACACS, TACACS+, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP)
1 x ARM Cortex-A9: 1.016 GHz
RAM
1 GB DDR3 SDRAM
Flash Memory
4 GB
20 x 1000Base-T RJ-45 PoE+ , 4 x 1000Base-T , 1 x serial (console) , 1 x USB Type B , 1 x 1000Base-T management
Expansion Slots
1 (total) / 1 (free) x Stacking Module , 1 (total) / 1 (free) x Expansion Slot
Internal power supply (not installed)
Max Supported Qty
2
80 PLUS Certification
80 PLUS Silver
CISPR 22 Class A, CISPR 24, EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN 61000-3-3, ICES-003 Class A, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1-07 Second Edition, VCCI Class A, IEC 60825-1:2007, CNS 13438, EN 55024:2010, EN 55022:2010, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 60825-1:2007, FCC CFR47 Part 15 A, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
44.25 cm
32.43 cm
4.39 cm
4.5 kg
Limited warranty - lifetime
55 °C
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
90% (non-condensing)
FBKJ Aruba SFP Transceiver Module 1000Base In Stock £113.35
FBKJ Aruba 10G SFP+ LC SR 300m MMF XCVR In Stock £371.56
Ports: 24
Managed: Yes
POE: PoE+
Brand: Aruba
Price Range Ex VAT: £1000 - £1500
