The HCG-620 is the perfect combination of power and efficiency. Delivering 620 continuous watts of power, the HCG-620 features a high-power +12V rail and special heavy-duty high current connectors and cabling that supply extreme levels of power. At the same time, the HCG- 620 delivers superb efficiency thanks to its 80 PLUS Bronze certification and Active PFC. High-quality gold-plated connectors, Japanese-brand capacitors and quiet 135 mm double ball bearing fans complete the package.
The connectors and power specifications of the HCG-620 PSU are all compatible with ATX12V v2.3 and EPS12V v2.91 specifications. The HCG-620 features universal input, which automatically senses when you connect the power supply to any AC power source between 100-240V without setting a voltage switch. This power supply also features Active Power Factor Correction (Active PFC), which improves the power factor value of the power supply by altering the input current wave shape, helping to power transmission across the grid.
High current power, low cost power supply
The HCG-620 is the perfect combination of power and efficiency. Delivering 620 continuous watts of power, the HCG-620 features a high-power +12V rail and special heavy-duty high current connectors and cabling that supply extreme levels of power. At the same time, the HCG- 620 delivers superb efficiency thanks to its 80 PLUS Bronze certification and Active PFC. High-quality gold-plated connectors, Japanese-brand capacitors and quiet 135 mm double ball bearing fans complete the package. -
Standards and features
The connectors and power specifications of the HCG-620 PSU are all compatible with ATX12V v2.3 and EPS12V v2.91 specifications. The HCG-620 features universal input, which automatically senses when you connect the power supply to any AC power source between 100-240V without setting a voltage switch. This power supply also features Active Power Factor Correction (Active PFC), which improves the power factor value of the power supply by altering the input current wave shape, helping to power transmission across the grid. -
System protection
A variety of industrial-grade safety circuitry will help protect your computer: OVP (Over Voltage Protection), SCP (Short Circuit Protection), OPP and OCP (Over Current Protection). Sometimes the PSU will "latch" into a protected state. You will need to power off the PSU and clear the fault before it will function again. There are no user-replaceable fuses in your HCG-620. -
80 PLUS certification
80 PLUS certification is a widely recognized independent standard in power supply efficiency. An 80 PLUS certified power supply uses less energy and generates less heat to stay cooler, run quieter and last longer. The HCG-620 has been 80 PLUS Bronze certified to be at least 82% efficient at a wide range of operating loads; this will lower your operating costs and help protect the environment.
- Antec High Current Gamer HCG-620 - power supply - 620 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3/ EPS12V 2.91
- 80 PLUS Certification
- 80 PLUS Bronze
- 2.1 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Power Capacity
- 620 Watt
- Output Current
- +5V - 24 A , +3.3V - 24 A , +12V - 48 A , -12V - 0.8 A , +5VSB - 2.5 A
- Output connectors
- 1 x 6 pin PCI Express power , 6 x 15 pin Serial ATA power , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x power 24 pin ATX with detachable 4 pin section , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 2 x 8 pin PCI Express power with detachable 2 pin section
- Cooling System
- 140 mm fan
- 15 cm x 16 cm x 8.6 cm
- 3-year warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Input Voltage Margin
- + 10% / - 10%
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Power Capacity
- 620 Watt
- Output Current
- 80 PLUS Bronze
- MTBF
- 100,000 hours
- Cooling System
- 140 mm fan
- Gold-plated terminals, over current protection, over voltage protection, overpower protection, short-circuit protection, single 12V rail, dual ball bearing cooling fan
- TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, RoHS, GOST-R
- Limited warranty - parts and labour - 3 years
- 15 cm
- 16 cm
- 8.6 cm
- 2.1 kg
- Shipping Width
- 27.3 cm
- Shipping Depth
- 18.1 cm
- Shipping Height
- 11.5 cm
- Shipping Weight
- 2.7 kg
