Eco-friendly Acer K2 Series monitors are affordable display solutions for everyday PC usage. They offer hassle-free usability without compromising image quality. The intelligent design brings together a multitude of connection ports, superb performance, and eco-friendliness - all at a price point that'll make you smile.
- Acer K272HLE - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class F
- Energy Consumption per Year
- 59 kWh
- Power Consumption (On mode)
- 41 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Screen Coating
- 3H Hard Coating
- Glossy black
- 64 cm x 23.5 cm x 46.3 cm
- 5 kg
- Environmental Standards
- ENERGY STAR Qualified
- MPR II, TUV, GS, ISO 9241-307
- 2-year warranty
- Display Type
- Energy Class
- Class F
- 59 kWh
- Diagonal Size
- 27"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Pixel Per Inch
- 82
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- 4 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- 3H Hard Coating
- Backlight Technology
- LED backlight
- HDCP, ComfyView, Zero Frame, Wide Viewing Angle, 72% NTSC colour gamut
- Glossy black
- 5 kg
- DVI (HDCP) , VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- MTBF
- 30,000 hours
- 41 W
- Power Consumption SDR (On mode)
- 26 kWh/1000h
- Power Consumption (Typical)
- 6 Watt
- Power Consumption Stand by
- 0.35 Watt
- Power Consumption Sleep
- 0.45 Watt
- 0.35 Watt
- Dimensions & Weight Details
- Width: 70.6 cm - depth: 48 cm - height: 14.1 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
