Direct Quick Print 3000 is a premium, smooth, bright white, direct thermal, paper labelstock. The thermally-sensitive top coating increases the battery life of your Zebra mobile printers, ensuring maximum printhead life. Its all-temperature, permanent adhesive provides premium cold temperature performance and adhesion to a variety of surfaces.
- Zebra Z-Select 2000D - labels - 25200 label(s) - 57.2 x 31.8 mm
- Product Type
- Labels
- Product Material
- Paper
- Adhesive Type
- Permanent adhesive
- Perforation
- Perforated
- Media Size
- 57.2 x 31.8 mm
- Printing Technology
- Direct thermal
- Card / Label Qty per Sheet/Roll
- 2100
- Qty of Media with Cards
- 12 roll(s)
- Included Qty
- 25200 label(s)
- Compatible with
- LP 2622, 2642, 2722, 2742, 2824, 2844, 3642, 3742; Orion; TLP 2622, 2642, 2722, 2742, 2824, 2844, 3642, 3742; Zebra DA402, GX420; GK Series GK420; G-Series GC420; GX Series GX420, GX430; H 2824; LP 2722, 2742, 2824, 2844; TLP 2722, 2742, 2824, 2844, 3742, 3842, 3844
Media
- Media Type
- Labels
- Product Material
- Paper
- Adhesive Type
- Perforation
- Perforated
- Media Sizes
- 57.2 x 31.8 mm
- Direct thermal
- Roll Maximum Outer Diameter
- 127 mm
- Roll Core Diameter
- 25.4 mm
- 2100
- 12 roll(s)
- Included Qty
- 25200 label(s)
- Perforation between labels
- Compatible with
- Eltron LP 2622, 2642, 2722, 2742, 2824, 2844, 3642, 3742 , Eltron Orion , Eltron TLP 2622, 2642, 2722, 2742, 2824, 2844, 3642, 3742 , Zebra DA402, GX420d, GX420t , Zebra GK Series GK420t , Zebra G-Series GC420t , Zebra GX Series GX420, GX430, GX430t , Zebra H 2824-Z , Zebra LP 2722, 2742, 2824, 2824 Plus, 2824-Z, 2844, 2844-Z , Zebra TLP 2722, 2742, 2824, 2824 Plus, 2824-Z, 2844, 2844-Z, 3742, 3842, 3844-Z
