Zalman CNPS5X-Performa Quiet Compact Tower CPU Cooler
Quicklinx: 8BR6WS00 Mfr#: CNPS5X PERFORMA
Three heatpipes and aluminum fins are designed for maximum cooling while cooler setup quickly expels hot air out of the case.
An ultra quiet 92 mm fan with FSB bearing is incorporated for minimized noise and excellent cooling.
Compatible with Intel LGA1155/1156/775 and AMD FM1/AM3+/AM3/AM2+/AM2/939/940/754
  • Powerful cooling performance
  • Ultra quiet 92 mm fluid shield bearing fan
  • PWM fan control
    The PWM (Pulse Width Modulation) fan automatically adjusts fan speed (RPM) according to the CPU's temperature.
  • Easy installation
    The cooler is designed with tool-less installation clip, making installation convenient.
ZALMAN CNPS-5X Performa - processor cooler
Processor cooler
Package Content
Thermal paste
Compatibility
Socket 754, Socket 940, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, LGA1150 Socket, Socket FM2
Heatsink Material
Aluminium and copper
Fan Diameter
92 mm
Fan Bearing
Fluid Shield Bearing
Rotation Speed
1400-2800 rpm
Noise Level
20 - 32 dBA
Rated Voltage
12 V
Pulse-width modulation (PWM) support, 6 copper heatpipes
6.4 cm x 12.7 cm x 13.4 cm
320 g
Processor cooler
Package Content
Thermal paste
6.4 cm
12.7 cm
13.4 cm
320 g
Heatsink & Fan
Compatible With
Processor Compatibility
Core 2 Duo - all speeds , Pentium 4 - all speeds , Celeron D - all speeds , Pentium D - all speeds , Core 2 Quad - all speeds , Core 2 Extreme - all speeds , Pentium Dual Core - all speeds , Core i7 - all speeds , Core i5 - all speeds , Core i3 - all speeds , Core i7 Extreme Edition - all speeds , Sempron - all speeds , Athlon - all speeds , Athlon 64 FX - all speeds , Opteron - all speeds , Phenom - all speeds , Athlon X2 - all speeds , Phenom II - all speeds , Athlon II - all speeds , AMD A Series - all speeds , FX Series - all speeds
Heatsink Material
Heatsink Dimensions
134 mm x 127 mm x 64 mm
Fan Diameter
92 mm
Fan Bearing
Rotation Speed
1400-2800 rpm
Noise Level
20 - 32 dBA
Rated Voltage
12 V
Mounting Kit
Included
