With EMI filter and safety certificates, Xigmatek launched the most suitable budget power supply for common users. Xigmatek VC series power supply means "Valued-Class" and offers the stable DC output and full electric protection with ideal cost/performance rate. VC series supports latest dual and quad cores CPU and mid-end graphic cards for home entertainment and gaming.
- XIGMATEK NRP-VC503 - power supply - 500 Watt
- Power supply - Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.2
- Input Voltage
- AC 115/230 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 500 Watt
- Output Current
- +12V1 - 15 A / 1 A , +12V2 - 16 A / 1 A , +3.3V - 22 A / 0.5 A , +5V - 16 A / 0.3 A , +5VSB - 2.5 A , -12V - 0.8 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 5 x 4 PIN internal power , 4 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector , 1 x 6 pin PCI Express power , 1 x power 8 pin +12V with detachable 4 pin section , 1 x 8 pin PCI Express power with detachable 2 pin section
- Cooling System
- 120 mm fan
- 15 cm x 14 cm x 8.6 cm
- ATX12V 2.2
- PSU Form Factor
- ATX
- Input Voltage
- AC 115/230 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 500 Watt
- Output Current
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Over current protection, over voltage protection, overload protection, undervoltage protection, short-circuit protection, temperature controlled fan, non-modular
- UL, TUV
- 5 °C
- 40 °C
- 5 - 85% (non-condensing)
- 15 cm
- 14 cm
- 8.6 cm
