The Xiaomi Redmi Note 11 Pro 5G gives you fast, smooth internet access for entertainment and gaming.
STUNNING VISUAL
The Xiaomi Redmi Note 11 Pro features a stunning 6.67 inch Full HD+ AMOLED screen (2400 x 1080, 120Hz) that ensures all your visuals are beautifully smooth. The balanced, bezel-less display achieves an impressive 20:9 aspect ratio - perfect for all your movies, websites, games and photos. Dual speakers on both the top and bottom of the device offer a more immersive sound experience.
GREAT CAMERAS
Shoot superb photos and video with the quad-lens rear camera featuring a 108MP main sensor, 8MP ultra-wide sensor, 2MP macro lens and 2MP depth sensor. Thanks to 9-in-1 pixel-binning and Dual native ISO technologies, you can capture stunningly detailed images with its improved processing and higher dynamic range. Redmi Note 11 Pro helps you get there with new creative photo and video features, including Pro time-lapse, Dual Video, Long exposure, telemacro, and ShootSteady modes. There's also an 16MP front camera for video chats and selfies.
LONG BATTERY LIFE
The Xiaomi Redmi Note 11 Pro features a 5000mAh battery that is built to last It's also compatible with 67W fast charging, so you get from flat to 51% in only 15 minutes.
Smoother, faster and more efficient
For those who want the ultimate experience, Snapdragon 695 5G processor is ready. -
5G arrived
Change the way you experience and share content with the power of 5G speed. Enjoy super-smooth gaming and streaming as well as ultra-fast sharing and downloading. -
108MP main camera - advanced to mature
Great 108MP flagship imaging system. Three cameras work together to capture magnificent landscapes, microcosms, stunning night scenes, high-level portraits... -
High refresh rate
120 Hz display gives you a higher refresh rate which will feel smoother and faster to use. -
6.67" FHD+ AMOLED display
Feast your eyes with vibrant details. -
As powerful as before
A massive battery that ensures you don't run out of battery while you are on the go. -
Much cooler than you thought
LiquidCool technology uses multiple layers of graphite and copper foil to dissipate heat, rapidly cooling the device through a massive heat dissipation area. -
Look powerful, feel powerful
Perfect combination of stylish camera and glass back. Slim flat-edge design is secure for holding in hands. When touching the frame, it feels very powerful.
- Xiaomi Redmi Note 11 Pro 5G - graphite grey - 5G smartphone - 128 GB - GSM
- Product Type
- 5G smartphone
- Display
- OLED display - 2400 x 1080 pixels - 6.67" - 395 ppi - (120 Hz) - AMOLED
- Processor
- Qualcomm Snapdragon 695 2.2 GHz (8-core)
- Graphics Accelerator
- Qualcomm ADRENO 619
- Memory
- RAM 6 GB / 128 GB
- Supported Memory Card
- microSDXC slot - up to 1 TB
- Operating System
- Android 11 with MIUI 13
- Main Camera
- 108 Megapixel - wide-angle lens - f/1.9 - focus: automatic
- Second Camera
- 8 Megapixel - ultra wide-angle lens - f/2.2
- Third Camera
- 2 Megapixel - f/2.4 - macro camera
- Front Camera
- 16 Megapixel f/2.4
- Service Provider
- Not specified
- SIM Card
- Dual-SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Security Devices
- Face recognition, fingerprint reader (side)
- Connectors
- 3.5 mm headset jack, USB-C
- Protection
- Dustproof, splashproof
- Graphite grey
- 76.1 mm x 8.12 mm x 164.19 mm
- 202 g
- Specific Absorption Rate (SAR)
- 0.596 W/kg (head) , 0.956 W/kg (body) , 1.995 W/kg (limb)
- 2-year warranty
- Product Type
- Smartphone
- Form Factor
- Touch
- Protection
- 76.1 mm
- 8.12 mm
- 164.19 mm
- 202 g
- Body Colour
- Graphite grey
- SAR Value
- 0.596 W/kg (head), 0.956 W/kg (body), 1.995 W/kg (limb)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 5G
- Service Provider
- Not specified
- Operating System
- Android 11
- User Interface
- MIUI 13
- Navigation
- GPS, GLONASS, BeiDou, Galileo
- SIM Card Qty
- Dual-SIM
- Input Device
- Multi-touch
Communications
- Data Transmission
- FDD-LTE, TDD-LTE, 5G NR FR1
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 4, Band 5, Band 8, Band 19
- 3G UMTS Frequency
- 2100, 1900, 1700, 850, 900, 800
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 26, Band 28, Band 32, Band 38, Band 40, Band 41, Band 66
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 850+, FDD 700 APT, FDD 1500 L, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
- 5G NR Band
- N1, n3, n5, n7, n8, n20, n28, n38, n41, n66, n77, n78, n40
- 5G NR Frequency
- FDD 2100, FDD 1800, FDD 850, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, FDD AWS-3, TDD TD 3700, TDD TD 3500, TDD 2300
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.1
Phone Features
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, digital compass, gyroscope
- Security Devices
- Security Technology
- AI face unlock
- Additional Features
- LiquidCool Technology, Z-axis linear vibration motor, IR blaster, write booster
Media Player
- Sound Enhancements
- Hi-Res audio certified
- Clock Speed
- 2.2 GHz
- Processor Core Qty
- 8-core
Graphics System
- RAM
- LPDDR4X SDRAM - 6 GB
- Internal Memory Capacity
- 128 GB
- Memory Interface
- UFS 2.2
- Supported Flash Memory Cards
- microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
- Sensor Resolution
- 16 Megapixel
- Lens Aperture
- F/2.4
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1280 x 720 (720p) at 30 fps
Main Camera
- Sensor Resolution
- 108 Megapixel
- Sensor Size
- 1/1.52"
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.9
- Pixel Size
- 0.7 µm
- Focus Adjustment
- Automatic
- Light Source
- LED flash
- Video Resolutions
- 9-in-1 pixel binning
Second Camera
- Sensor Resolution
- 8 Megapixel
- Lens Type
- Ultra wide-angle lens
- Lens Aperture
- F/2.2
- Field of View (FoV)
- 118 degree(s)
Third Camera
- Sensor Resolution
- 2 Megapixel
- Lens Aperture
- F/2.4
- Functions
- Macro camera
Display
- OLED display
- Technology
- AMOLED
- Diagonal Size
- 6.67"
- Display Resolution
- Display Format
- Full HD+
- Pixel Density
- 395 ppi
- Max Brightness
- 1200 cd/m²
- Enhancement Technology
- Sunlight mode, Reading mode 3.0
- Refresh Rate
- 120 Hz
- Contrast Ratio
- 4500000:1
- DCI-P3 Wide colour gamut, Dot Display
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Capacity
- 5000 mAh
- Included Accessories
- SIM card removal tool, USB-C cable, protective case, 67W charger
- Limited warranty - 2 years
