The slim and sleek flat frame design of the note 11
Coming in 3 different colours graphite grey, twilight blue and star blue making it perfect for any user. The note 11 has a thickness of just 8.09mm and weight of 179g
Amoled display
- 6.43" FHD+ Amoled DotDisplay
- DCI-P3 Wide Colour gamut for rich colour representation
- 4,500,000:1 Contrast ratio for sharp images
- Sunlight display, allows the screen to be readable in bright sunlight
- Reading mode 3.0, Relieves eye strain
Seamless touchscreen and display
Enjoy your content in smooth and seamless 90Hz high refresh rate. Scroll through your social media feeds in comfort or experience powerful and responsive gaming.
All-around performance with the 6nm Snapdragon 680
This processor is not only fast and powerful, but also runs on the energy efficient 6nm process to give you high performance while improving battery life. Faster loading speeds with UFS 2.2 and accelerated writing with the Write Booster — effective high-speed app installation, initiation and file cache functions, as well as large-file reading and writing.
33W Pro fast charging and massive 5000mAh battery
100% charge in just over 1 hour with the 33W pro fast charging
Powerful 50MP Quad Camera System
- 50MP main camera
- 8MP ultra-wide camera
- 2MP Macro camera
- 2MP Depth camera
Plus, a 13MP Selfie camera
Smarter and more convenient
- Memory extension
- Dual Stereo speaker
- Multifunctional NFC for quick convenient mobile payments
- IR Blaster for easy control of your home appliances
- Z axis linear motor for excellent haptic feedback
Design so good, you just can't get enough of it
Taking perfection a notch higher with the stunning EVOL. Design. -
90Hz FHD+ AMOLED Display
Display so fine, it will blow your mind. Brace yourself for an 11 on 10 viewing experience on the splendid AMOLED Display. -
90Hz Refresh Rate - irresistibly smooth
High Refresh Rate of 90Hz means smoother scrolling and graphics resulting in outstanding user experience. -
Sunlight Display
Designed to adjust your screen brightness according to the sunlight. -
Reading Mode 3.0
Designed for eye comfort. -
Qualcomm Snapdragon 680 - efficiency has a new name
Built on 6nm architecture, it is designed to give you superior performance while conserving power. Get ready for 11 on 10 experience! -
Massive 5000mAh Battery 33W Pro Fast Charging - juice up in no time
With 33W Pro Fast Charging and 5000mAh Battery, get ultra-long battery life and improved charging efficiency. -
Turn up the cool quotient
Consistent peak performance with Multiple graphite sheets for heat dissipation. More effective thermal conductivity with an upgraded cooling system and multiple layers of graphite sheets. -
Turn up the volume
Dual stereo speakers. Immersive audio quality.
- Processor
- Snapdragon 680
- Storage and Ram
- 4GB + 128GB Expandable up to 1TB
- Dimensions
- H: 159.87mm W:73.87mm D:8.09mm Weight 179g
- Display
- 6.43" FHD+ Amoled DotDisplay,
- Battery and Charging
- 5000mAh, 33w pro fast charging, 33W in-box charger, USB-C
- Security
- Side fingerprint sensor, AI face unlock
- NFC
- Availability varies between market
- Network
- Sim Free, Dual Sim + MicroSD
- Connectivity
- 4G, 3G, 2G, Bluetooth 5.0, Wifi
- Audio
- Dual Speakers, 3.5 headphone jack
- Senors
- Promximity, Ambient light, Accelerometer, Electronic compass, IR blaster, Gyroscope
- Operating system
- MIUI 13 based on Android 11
- Package contents
- Redmi note 11, adapter, USB type C Cable, Sim eject tool, Protective case, Quick start Guide, Warranty card
