Redmi Buds 3 Pro, the sound you want
35dB Active noise cancellation - 3 settings available for adjustments
Fast charging - Use for up to 3 hours after just ten minutes of charging
Dual device smart connectivity - Compatible with multiple systems
Wireless Charging - Charging starts when the case is in range
AI Scene judgement - adjust the depth of adaptive noise cancellation
Dual transparency mode - Allows you to converse freely while wearing the earbuds
29 hours playback - up to 28 hours long listening with the case
35dB deep noise cancellation, Allowing you to enjoy a world with less background noise
The earbuds adopt the dual active noise cancellation technology with feedback and feed-forward microphones. They effectively cancel ambient noise and reduce excess noise in the ear canal. Noise cancellation can be as deep as 35dB.
Three-microphone call noise cancellation Can be heard clearly in noisy environments
The three microphones, together with the call noise cancellation algorithm enabled through the neural network model, can accurately pick up people's voices while effectively reducing background ambient noises. This allows for clear conversations without interference in noisy environments.
Dual transparency mode* Hear ambient sounds without having to take out the earbuds
When transparency mode is turned on, you can still hear ambient sounds without having to take out the earbuds. Switch to enhance voice mode for clearer voice. You can have a relaxed conversation with your friend with your earphones on.
28-hour ultra-long battery life* Continue to enjoy your music
With a built-in low-power chip, the earbuds can operate up to 6 hours* for a single charge. With the assistance of a charging case, the earbuds can operate up to 28 hours*. Thus, you can enjoy music for hours on end.
6 hours Single use (with noise cancellation off)
28 hours Overall battery life (with noise cancellation off)
Supports fast charging and wireless charging
With fast charging, the earphones can charge for just 10 minutes and then allow you to listen to music for up to 3 hours. If the battery is running low, take a short break and let it power up. The charging case also supports Qi wireless charging, making charging super convenient.
Music playback up to 3 hours after charging for 10 minutes
Capable of connecting to two devices simultaneously Smart switching between entertainment and work
The same set of earbuds can be connected to two devices crossing platforms such as Android, iOS, and Windows simultaneously, allowing you to easily switch between entertainment and work. Pairs with Bluetooth through opening the earbud box near your phone* or by quickly clicking the pop-up window* which enables you to enjoy the new fast connection method.
Tap twice to answer the call
Touch the rear of the earbuds for controls including switching modes, music pause and playback etc. Also supports the wake-up voice control feature.
Tap twice Answer/hold the call Music playback / pause
Press and hold either earbud Noise cancellation / transparency Switching mode
Tap three times Switch to the next song Hang up a call
In-ear detection
Music can be automatically paused when the earbuds are taken out. Music playback can be resumed when they are put back on.
IPX4 water resistant
All-round splash resistant, protecting users from sweat and splash.
Availability of multiple silicone ear tips
Offers three sizes of eartips including large, medium and small, providing a more comfortable user experience.
Find your earphones
Within the range of Bluetooth connectivity, you can locate your earbuds by sound.
Package contents
Charging case ×1 Earbuds ×2 Ear tips ×3 pairs (S/M/L/, M pre-installed) Charging cable ×1 User manual ×1
- Earbuds Charge time
- Approx 1 Hour
- Wireless connection
- Bluetooth 5.2
- Charging Case charge time
- 2.5 hours (wired)
- Single earbud weight
- 4.9g
- total weight including charging case
- 55g
- Call Duration
- Approx 3 hours (ANC off 50% Volume)
- Communication Range
- 10m
- Music Playback time
- Approx 6 hours (ANC off 50% Volume)
- Charging Port
- USB-C
