- Manufacturer: XFX
- Chipset: Radeon R5 230
- Core Clock: 625 MHz
- Memory: 1GB
- Memory Bit Rate: 64 Bit
- Interface: PCIe 3.0 (x16)
- Streams: 80
- Cooling: Passive
- Connectivity: 1 x D-Sub, 1 x Dual Link DVI-D, 1 x HDMI
- Maximum Digital Resolution: 2560x1600
- Maximum VGA Resolution: 2048x1536
- Multi Monitor: 2 displays
- Low Profile Support: Yes
- Package Type: Retail
Next generation gaming graphics
Fully supported Microsoft DirectX 11.2, with 4x faster tessellation rendering and massive virtual texture dynamic loading for more intense performance over earlier products. -
Multi monitor daily productivity
See all your programs at the same time without having to switch. Be more productive and get more done quickly. -
Multi monitor professional audio editing
See all your track, equalizers, samples and editors all the same time. Be more productive and get more done quickly. -
Multi monitor gaming
See more real-life peripheral vision around sides and see enemies you would have missed in single monitor.
- XFX Radeon R5 230 - Core Edition - graphics card - Radeon R5 230 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.1
- Graphics Engine
- AMD Radeon R5 230
- Memory
- 1 GB DDR3
- Core Clock
- 625 MHz
- Stream Processors
- 80
- Effective Memory Clock
- 1066 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x 1536
- HDMI , DVI-D (dual link) , VGA
- API Supported
- DirectX 11.2
- Fanless
- 1.41 cm x 17.2 cm x 6.88 cm
- Graphics card - fanless
- Bus Type
- PCI Express 2.1
- Graphics Engine
- AMD Radeon R5 230
- Core Clock
- 625 MHz
- Stream Processors
- 80
- Max Resolution
- 2560 x 1600
- API Supported
- DirectX 11.2
- AMD HD3D Technology, AMD PowerPlay technology, AMD Unified Video Decoder (UVD) 3, AMD Hybrid Graphics Technology, 3rd Generation TeraScale Engine
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1066 MHz
- Bus Width
- 64-bit
- Required Power Supply
- 400 W
- Included Accessories
- 2 low-profile brackets
- Software Included
- Drivers & Utilities
- RoHS
- 1.41 cm
- 17.2 cm
- 6.88 cm
