The XFX AMD Radeon R5 230 graphics card delivers discrete graphics performance that's perfect for every day computing. Multitask with AMD's EyeSpeed technology and accelerate applications. Eyefinity technology lets you spread work across up to three displays so you can watch movies in vivid HD and multitask with impressive speed. With DirectX 11, the XFX AMD Radeon R5 230 graphics card gets a performance boost, delivering advance technologies with superb DirectX 11 support.
Next generation gaming graphics
Fully supported Microsoft DirectX 11.2, with 4x faster tessellation rendering and massive virtual texture dynamic loading for more intense performance over earlier products. -
Multi monitor daily productivity
See all your programs at the same time without having to switch. Be more productive and get more done quickly. -
Multi monitor professional audio editing
See all your track, equalizers, samples and editors all the same time. Be more productive and get more done quickly. -
Multi monitor gaming
See more real-life peripheral vision around sides and see enemies you would have missed in single monitor.
- XFX Radeon R5 230 - Core Edition - graphics card - Radeon R5 230 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0
- Graphics Engine
- AMD Radeon R5 230
- Memory
- 2 GB DDR3
- Core Clock
- 625 MHz
- Stream Processors
- 80
- Effective Memory Clock
- 1066 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x 1536
- HDMI , DVI-D (dual link) , VGA
- API Supported
- DirectCompute 11, OpenGL 4.3, DirectX 11.2, Mantle
- Fanless
- 1.88 cm x 16.8 cm x 11.2 cm
- Graphics card - fanless
- Bus Type
- PCI Express 3.0
- Graphics Engine
- AMD Radeon R5 230
- Core Clock
- 625 MHz
- Stream Processors
- 80
- Max Resolution
- 2560 x 1600
- API Supported
- Video Transcoding (AVT), AMD HD3D Technology, AMD PowerPlay technology, AMD Unified Video Decoder (UVD) 3, AMD Stream technology, Deep Color technology, 3rd Generation TeraScale Engine, Shader Model 5.0, Horizon-Based Ambient Occlusion (HBAO), HDR texture compression, GPU Tessellation
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1066 MHz
- Bus Width
- 64-bit
- Required Power Supply
- 400 W
- Included Accessories
- 2 low-profile brackets
- Software Included
- Drivers & Utilities
- RoHS
- 1.88 cm
- 16.8 cm
- 11.2 cm
