WD 8TB My Book 3.5" USB3.0 Desktop Hard Drive
Quicklinx: CFGRWS00 Mfr#: WDBBGB0080HBK-EESN
Form Factor: 3.5
Capacity: 8TB
Interface: USB 3.0
Select:
  • 8TB
£192.86 ex VAT
£231.43 inc VAT
My Book
The My Book desktop hard drive is designed to complement your personal style with a massive amount of space to store your photos, videos, music and documents.
Complete Backup, Time Machine-Compatible
Equipped with WD Backup software for Windows and Apple Time Machine compatibility for Mac, the My Book desktop hard drive can back up your photos, videos, music and documents. The My Book desktop hard drive also works great with Acronis True Image WD Edition software to schedule full system backups.
Password Protection with Hardware Encryption
With built-in 256-bit AES hardware encryption with WD Security software, you can set your own personalized password to help keep your content private and safe.
Easy to Use
Ready to use out of the box, start transferring files, saving memories and backing up. WD Backup and WD Security software are included to help protect your data. The My Book drive is also compatible with Apple Time Machine.
Reimagined Design
The compact design of the My Book drive exudes a confidence reflective of its reliability. With up to 8TB of storage capacity, you can trust your My Book drive to be the home of your digital life.
Massive Capacity
With up to 8TB of capacity, there's plenty of room to save the massive amounts of photos, videos, and music you love, plus your important documents.
WD Quality Inside and Out
Millions of people around the world trust their data to the My Book desktop hard drive. Designed to meet WD's demanding requirements for durability, shock tolerance and long-term reliability, we stand by the trusted My Book desktop storage with a 2-year limited warranty
  • Password protection
    With built-in 256-bit AES Hardware Encryption with WD Security software, just set your own personalized password to help keep your content private and safe.
  • Reimagined design
    Surprisingly compact, the design of My Book desktop storage exudes a confidence reflective of its reliability. With big storage capacity, you can trust My Book to be the home of your digital life.
  • Easy to use
    Ready to use out of the box, start transferring files, saving memories and backing up right away.
WD My Book WDBBGB0080HBK - hard drive - 8 TB - USB 3.0
Hard drive - external (desktop)
8 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Password authentication, hardware encryption, automatic backup, exFAT formatted
Power Source
Included AC adapter
Enclosure Colour
49 mm x 139.3 mm x 170.6 mm
960 g
EMEA
8 TB
Hardware Encryption
256-bit AES
USB 3.0
49 mm
139.3 mm
170.6 mm
960 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Power adapter
Software Included
WD Security, WD Drive Utilities, WD Backup
Windows 10 or later, Apple macOS 11 or later
1 x USB 3.0 cable - external
Directive 2002/95/EC, NRCAN
Enclosure Colour
EMEA
Package Type
Retail
5 °C
35 °C
Form Factor: 3.5
Capacity: 8TB
Interface: USB 3.0
Brand: WD
