Finally, a drive can keep up with your creativity. Video editors and other digital media professionals can do more work in less time with the ground-breaking data transfer speed of the Thunderbolt ports on My Book Thunderbolt Duo drive. It offers the indisputably fast way to get information to and from your external drive.
My Book Thunderbolt Duo, dual-drive storage system featuring Thunderbolt technology, sets new standards for data transfer speeds and workflow flexibility in an affordable, high-capacity storage system.
Move data at unprecedented speeds
Finally, a drive can keep up with your creativity. Video editors and other digital media professionals can do more work in less time with the ground-breaking data transfer speed of the Thunderbolt ports on My Book Thunderbolt Duo drive. It offers the indisputably fast way to get information to and from your external drive. -
High-capacity storage
My Book Thunderbolt Duo, dual-drive storage system featuring Thunderbolt technology, sets new standards for data transfer speeds and workflow flexibility in an affordable, high-capacity storage system. -
User-configurable RAID for speed or double-safe data protection
You can select the RAID mode that's right for you. Choose RAID 0 (striping) for the performance you need when designing or editing graphic-intensive media files. When the drive is set to RAID 1 (mirroring) it provides double-safe data protection by automatically generating a duplicate copy of your data. Set the drive to JBOD (Just a Bunch Of Disks) to use as two individual drives and select between HFS+J or ExFAT per disk. -
Daisy chain several drives together for even faster speed
The intelligent Thunderbolt connector provides two channels of up to 10 Gb/s transfer rate in both directions. This means data can travel both ways without compromising bandwidth. Add to that the power of multiple drives processing data and you get amazing speed. -
High-speed multi-tasking
Bi-directional Thunderbolt technology delivers unmatched speed for multi-tasking while video editing, 3D rendering and completing other graphics-intensive projects.
- WD My Book Thunderbolt Duo WDBUTV0040JSL - hard drive array
- Hard drive array
- Total Array Capacity
- 4 TB
- Interface
- Thunderbolt
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- Localisation
- Middle East, Africa, Europe
- Storage Controller
- RAID RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 2 TB HDD
- OS Required
- Apple MacOS X 10.6.8 or later
- Power
- AC 120/230 V - 50/60 Hz
- 9.9 cm x 15.7 cm x 16.5 cm
- 2.15 kg
- 3-year warranty
- Hard drive array
- Localisation
Chassis
- 2
- Supported Devices / Modules Qty
- 2
Storage
- 4 TB
- HDD Array External Interface
- Thunderbolt
Storage Controller
- RAID
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD
- Capacity
- 2 x 2 TB
- Expansion Bays
- 2 (total) / 0 (free) x internal
- 2 x Thunderbolt
- OS Required
- Cables Included
- 1 x Thunderbolt cable
- Software Included
- WD Drive Utilities
- RoHS
- Power Device
- External power adapter
- Voltage Required
- 9.9 cm
- 15.7 cm
- 16.5 cm
- 2.15 kg
- Limited warranty - 3 years
- 5 °C
- 35 °C
