Sophisticated performance enhancing features deliver the speed you need for demanding applications like photo and video editing and Internet gaming.
High performance, high capacity, high reliability, and cutting-edge technology make up WD Black, the ideal drive for those who demand only the best.
Maximum performance
Sophisticated performance enhancing features deliver the speed you need for demanding applications like photo and video editing and Internet gaming. -
No compromises
- WD Black Performance Hard Drive WD3003FZEX - hard drive - 3 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 3 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 64 MB
- Spindle Speed
- 7200 rpm
- StableTrac, NoTouch ramp load technology, dual processor, Advanced Format technology, S.M.A.R.T.
- 101.6 mm x 147 mm x 25.4 mm
- 780 g
- 5-year warranty
- Capacity
- 3 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- 101.6 mm
- 147 mm
- 25.4 mm
- 780 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 168 MBps
- Spindle Speed
- 7200 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 300,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" x 1/3H
- Power Consumption
- 9.5 Watt (read) , 8.1 Watt (idle) , 1.3 Watt (standby) , 1.3 Watt (sleep)
- RoHS, WEEE
- Limited warranty - 5 years
- 5 °C
- 55 °C
- Shock Tolerance
- 65 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
- Sound Emission
- 29 dBA
