With the blazing-fast connectivity of USB 3.0, this drive lets you access and save files in record time. Reduce transfer time by up to 3 times when compared to USB 2.0 transfer rates.
Ultra-fast USB 3.0 connectivity
With the blazing-fast connectivity of USB 3.0, this drive lets you access and save files in record time. Reduce transfer time by up to 3 times when compared to USB 2.0 transfer rates. -
Massive capacity in a small design
This compact enclosure offers up to a massive 2 TB of storage. It's the ideal companion for anyone with lots of photos, movies, videos and files that they want to take with them. -
Password protection secures your drive
Use WD security utility to set password protection and hardware encryption and protect your files from unauthorized use or access. -
USB 3.0 interface
Conveniently powered through the USB 3.0 interface, you can quickly connect to your MacBook or MacBook Air and access your files. There's no need to carry around a power adapter.
- WD My Passport for Mac WDBZYL0020BSL - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 2 TB
- Hardware Encryption
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Password authentication, hardware encryption, Apple Time Machine compatible
- Power Source
- USB bus
- Enclosure Colour
- Silver
- 110.8 mm x 82.3 mm x 21 mm
- 230 g
- Localisation
- Middle East, Africa, Europe
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.0
- 110.8 mm
- 82.3 mm
- 21 mm
- 230 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- Software Included
- WD Security, WD Drive Utilities
- OS Required
- Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion
- Cables Included
- 1 x USB cable - external
- RoHS
- Enclosure Colour
- Silver
- Localisation
- Limited warranty - 3 years
- 5 °C
- 35 °C
