WD VelociRaptor drives offer an unmatched combination of high performance and high reliability, perfect for workstations, high-end video and photo editing, low-end servers and performance enthusiast's systems. Comes with a 3.5-inch mounting frame for easy installation into today's high-performance systems and chassis.
- Ultra fast - Designed around a 10,000 RPM spin speed, these SATA 6 Gb/s drives include a 64 MB cache and deliver the ultimate performance for photo and video editing.
- Rock-solid reliability - With 1.4 million hours MTBF, these drives have the highest available reliability rating on a high capacity SATA drive.
- High capacity - State-of-the-art technology delivers a balance of high performance and high capacity perfect for data-intensive workloads that require large amounts of storage such as video editing, 3D rendering and scientific modeling.
- Ultra-cool operation - Consumes less idle power and uses similar active power as the previous generation WD VelociRaptor, while offering higher capacity and performance.
- Advanced Format (AF) - Technology adopted by WD and other drive manufacturers as one of multiple ways to continue growing hard drive capacities. AF is a more efficient media format that enables increased areal densities.
- IcePack™ mounting frame - The 2.5-inch hard drive is enclosed in a backplane-ready 3.5-inch mounting frame with a built-in heat sink that keeps this powerful little drive extra cool when installed in high-performance desktop chassis.
- NoTouch&trade ramp load technology - The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
- Pre-emptive Wear Leveling (PWL) - Ensures reliability for applications that perform a high incidence of read/write operations at the same physical location on the disk.
- Rotary Acceleration Feed Forward (RAFF™) - Optimizes operation and performance when the drives are used in vibration-prone, multi-drive chassis.
- Environmentally Conscious - In addition to being RoHS compliant, this generation of WD VelociRaptor also provides a halogen-free design.
Specification
- 1TB Capacity
- 10,000 RPM
- SATA 6Gb/s
- Windows 7/Vista/XP/2000, Windows servers, Linux, and Mac OS.
- 5-year limited warranty
Designed and manufactured to mission-critical enterprise-class standards to provide enterprise reliability in high duty cycle environments. This drive has the highest available reliability rating on a high-capacity SATA drive. -
It consumes no more power than the previous generation WD VelociRaptor while offering double the capacity and higher performance. -
Rotary Acceleration Feed Forward (RAFF)
It optimizes operation and performance when the drives are used in vibration-prone, multi-drive chassis. -
NoTouch ramp load technology
The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit. -
Environmentally conscious
In addition to being ROHS compliant, this WD VelociRaptor is also a halogen free design.
- WD VelociRaptor WD1000DHTZ - hard drive - 1 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 1 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 64 MB
- Spindle Speed
- 10000 rpm
- Rotary Acceleration Feed Forward (RAFF), Preemptive Wear Leveling (PWL), IcePack mounting frame, NoTouch ramp load technology, Advanced Format technology, S.M.A.R.T.
- 10.2 cm x 14.7 cm x 2.6 cm
- 499 g
- 5-year warranty
- Capacity
- 1 TB
- Form Factor
- 3.5" x 1/3H
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- 10.2 cm
- 14.7 cm
- 2.6 cm
- 499 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 200 MBps
- Spindle Speed
- 10000 rpm
Reliability
- Non-Recoverable Errors
- 1 per 10^16
- Start / Stop Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 3.5" x 1/3H
- RoHS
- Limited warranty - 5 years
- 5 °C
- 55 °C
- Shock Tolerance
- 65 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
