WASP WPL614 Industrial Barcode Printer
Quicklinx: GB7WWS00 Mfr#: 633809003479
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: Roll (11.4 cm)
£900.29 ex VAT
£1,080.34 inc VAT
The Wasp WPL614 industrial barcode printer is rugged, affordable and includes an advanced set of features to ensure years of performance in a range of applications including manufacturing, transportation, healthcare and retail. Durable construction, premium print head technology, faster processor and more than enough memory to excel in applications that demand high quality labels printed at fast speeds.
The WPL614 industrial barcode printer is both versatile and easy to use with features like direct thermal and thermal transfer printing, 6-button color LCD resistive touch screen for fast configuration and enhanced print quality, "Thermal Smart Control", which tracks and precisely calculates the duration that each pixel needs to be heated to provide accurate, crisp and clear labels every time, whether you are printing one label at a time or thousands of labels in a batch.
Print speed of up to 14 inches per second at 203 DPI resolution is supported by 512 MB of SDRAM, and 512 MB of Flash memory, making the WPL614 ideal for high volume print applications. Designed to grow with your evolving business needs, the WPL614 includes ZPL, EPL, and WPL emulation to ensure application compatibility and flexibility. Standard connectivity options include RS-232, USB 2.0, internal Ethernet (10/100 Mbps), USB host (for scanner or PC keyboards).
Wasp WPL614 - label printer - B/W - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - B/W
18.93 kg
Max Media Size
Roll (11.4 cm)
Max Media Size (Custom)
114.3 mm
Print Speed
Up to 356 mm/sec
Max Resolution (B&W)
203 dpi
USB 2.0, LAN, serial, USB host
RAM Installed (Max)
256 MB SDRAM
Flash Memory Installed (Max)
512 MB
Language Simulation
ZPL, ZPL II, EPL, WPL
Barcodes
Code 93, Code 39, Code 49, QR code, MaxiCode, Aztec code, Telepen, LOGMARS, UPC-A, UPC-E, MicroPDF417, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, Data Matrix, PLANET, TLC39, China Post, Codablock F, Plessey, EAN-14, Code 128B, Code 128C, German Post, Code 128A, ITF-14, EAN-128, EAN-8, EAN-13, MSI, RSS
Media Type
Labels, continuous forms, fanfold paper, die cut labels
Black Mark sensor, gap sensor, ribbon end sensor, ribbon encode sensor, open head sensor
Total Media Capacity
1 roll
27.6 cm x 50.2 cm x 41.2 cm
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
Printer
Print Speed
Up to 356 mm/sec - 203 dpi
Built-in Devices
4.3 inch LCD touch screen
Wired
203 dpi
Language Simulation
Barcodes
RAM
RAM Installed (Max)
256 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
512 MB
Media Handling
Media Type
Max Media Size
Roll (11.4 cm)
114.3 mm
Media Sizes
Roll (11.4 cm)
Max Printing Width
104 mm
Max Printing Length
25400 mm
Media Thickness Range
0.06 mm - 0.28 mm
Roll Core Diameter
76.2 mm, 38.1 mm
1 roll
Media Feeders
1 x manual - 1 roll - Roll (11.4 cm)
1 x USB 2.0 , 1 x RS-232 , USB host - 4 pin USB Type A , 1 x LAN - RJ-45
1 x USB cable
FCC Class A certified, UL, TUV, cUL, RoHS, WEEE, KC, BIS, RCM Class A
Power supply - internal
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
5 °C
25 - 85% (non-condensing)
27.6 cm
50.2 cm
41.2 cm
18.93 kg
Type: Printer
Brand: WASP
Price Range Ex VAT: £750 - £1000
