For creative professionals such as photographers, designers and illustrators or anyone who desires professional results, the Intuos5 touch Small Pen Tablet combines Wacom's most advanced pen technology with multi-touch functionality. Natural and intuitive to use, the tablet lets you alternate between using multi-touch gestures to position and navigate your artwork and the pressure-sensitive pen to sketch, paint, retouch, and edit.
To achieve its compact size, the small Intuos5 touch has two fewer ExpressKeys than the other sizes, but brings all of the same great pen and multi-touch control as you will find in other Intuos5 touch models. The small tablet is ideal for limited desktop areas, or for those who want a highly portable, professional-level tablet that fits comfortably in a laptop bag.
The human touch
The addition of multi-touch to the Intuos5 gives you an alternate input method. It's natural to use and the perfect complement to the pen in your creative process. Totally immerse yourself in your creative work as you use one hand to pan, zoom and rotate your canvas, and then use your pen to precisely create your work. -
Keep your eyes on your work
With Intuos5, set-up the ExpressKeys for your own unique configuration of time-saving shortcuts and modifiers. If you ever need a reminder of an ExpressKey function, lightly rest your finger on the capacitive ExpressKey, and see an instant, on-screen reminder of the key's function. -
Professional pen performance
In order to simulate traditional pens, markers and brushes, the Intuos5 Grip Pen features 2048 levels of pen pressure sensitivity as well as pen tilt recognition. Varying the pressure of the pen against the tablet can create variations in line width and opacity or can be used to create unique brush effects. -
Modern ergonomic design
The innovative design of Intuos5 features soft-touch, matte-black finish with illuminated accents. The ergonomic design allows you to flip the Intuos5 tablets in either direction to suit left-handed or left- or right-handed use. Available in three wide-format sizes, small, medium and large, you can choose the perfect size to fit your specific working style and workflow needs. -
Wacom tip sensor
Featuring Wacom's innovative pen tip sensor, Intuos5 captures the slightest nuance of pen pressure starting with only a single gram of pressure. With every stroke, Intuos captures even the most subtle nuances of pressure, giving you the creative power to dynamically adjust exposure, brush size, line weight, opacity and more by pressing harder or softer with the pen. -
Customizable ExpressKeys
With the Intuos5 ExpressKeys, you will work smarter, not harder. Use the default short cuts already set to the ExpressKeys, or set your own application specific shortcuts. Combined with the on-screen ExpressView, you will have easy reference to all your short cuts, so you can fly through your work more intuitively than ever. -
Multi-function touch ring
A favorite feature among Intuos users, the finger-sensitive multi-function touch ring provides you with control of up to four-user defined functions such as scrolling, zooming, brush size, canvas rotation and more. -
Convenience
The lightweight pen stand not only provides a convenient pen holder, but also functions as a handy twist-off storage compartment for pen nibs and handy nib removal tool. Standard, felt, stroke and flex nibs ship with the Intuos5, allowing you to simulate working with a variety of traditional art and design materials.
- Wacom Intuos5 Touch Small - digitiser - USB - black
- Digitiser
- Connectivity Technology
- Wired - USB
- Black
- Orientation
- Right and left-handed
- 32 cm x 20.8 cm x 1.2 cm
- 0.66 g
- Localisation
- English
- Buttons Qty
- 6
- Movement Resolution
- 5080 lpi
- Accuracy
- ± 0.25 mm
- Pressure sensitive pen, eraser, finger-sensitive Touch Ring, 6 ExpressKeys, status led, multi-touch digitiser
- Cables Included
- 1 x USB cable - detachable - 2 m
- OS Required
- Microsoft Windows Vista SP2, Apple MacOS X 10.5.8 or later, Microsoft Windows XP SP3, Microsoft Windows 7 SP1 or later
- Microsoft Certification
- Compatible with Windows 7
- Digitiser
- Orientation
- 32 cm
- 20.8 cm
- 1.2 cm
- 0.66 g
- Black
- Localisation
- English
Input Device
- Wired
- Interface
- USB
- Buttons Qty
- 6
- 5080 lpi
- Accuracy
- ± 0.25 mm
- Pressure Levels
- 2048
- Active Area
- 15.7 mm x 9.8 cm
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Pen stand, nib removal tool, nibs (10 pcs.), colour identification rings
- Cables Included
- Software Included
- Drivers & Utilities
- OS Required
Wacom Intuos5 Pen & Touch Small
