Vogels Short-throw Projector Mount
Quicklinx: 62S8WS00 Mfr#: VOGPPS800/SI
The PPS 800 projector mount is specially designed for the new generation short throw projectors up to 10kg. This wall mount has unique features for short throw applications and is fitted with a universal adapter.
The PPS 800 wall mount is especially designed for the new generation short throw projectors. This wall mount has unique features especially for short throw applications and will save a lot of installing and adjustment time. On top of that this wall mount has a stylish design and a lightweight aluminum construction.
Vogel's PPS 800 - mounting kit - for projector - silver
Mounting kit - wall-mountable
Mounting Components
Short throw wall mount
Adjustments
Tilt
9.8 kg
Recommended Use
Projector
Max Load Weight
15 kg
Silver
5-year warranty
9.8 kg
Silver
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Projector
Placing / Mounting
Wall-mountable
Adjustments
Tilt
Max Load Weight
15 kg
Adjustable height, adjustable depth, Fine Tune Mechanism (VFT), horizontal shift
Limited warranty - 5 years
