Vision V2 STEREO AMPLIFIER LED displa
Quicklinx: 7C92WS00 Mfr#: TC2-AMP2
By using low-impedance digital amplifier chip technology the Techconnect AMP2 module outputs a massive 2 x 20w RMS (at 8 ohms) but fits into the space of a Techconnect module.
Digital amplifiers use no power unless they are amplifying program, so even on at full volume; unless it is receiving input it is effectively off. Digital amplifiers also have the advantage of running cold so a bulky heatsink is not necessary but don't let size deceive you: the Techconnect AMP2 can drive into a 4 ohm load allowing you to power up to four speakers.
A clear display makes the product easy to use and a simple soft-control interface gives instant access to controls. Because the control panel can be installed anywhere in the room it is more convenient than traditional powered speakers where access to the controls can be awkward.
  • Quick-access input
    Two inputs are wired into the rear with removable phoenix connectors, however a feature of this amplifier is that input 1 is duplicated on the front panel with a mini jack socket for convenience.
  • Green D-Class amplifier
  • LED display
  • Easy to install and uninstall
    Vision has paid special attention to creating a robust product that is simple and easy to install; the inputs and outputs are all via removable phoenix connectors which allow non-technical end users to uninstall it very easily if required. Short input cables are included for connection to the rear of adjacent input modules on the Techconnect.
  • Wall mounted and secure
    Ideal when you don't have furniture to sit an amplifier on, and because it is mounted to the wall it is much less obvious as a target for theft. It is close at hand if volume adjustments need to be made, making it perfect for training rooms, boardrooms, and classrooms.
  • Laptop-style power supply
    A DC tail which can be shortened means easy routing of power cable through trunking. Velcro is included for fixing the power supply in place, or a blank surround is available to hide it in a standard.
Vision Techconnect TC2-AMP2 - amplifier
Amplifier
Enclosure Colour
White
Audio Channels
Stereo
Audio Specifications
Amplifier - 80 - 22000 Hz - 98 dB
Frequency Response
80 - 22000 Hz
Output Power
40 Watt
Display
LED display
Remote Control
Remote control
4.2 cm x 4 cm x 7.1 cm
63 g
Amplifier
Enclosure Colour
White
Audio System
Audio Channels
Stereo
Functions
Amplifier
Amplifier - Response Bandwidth - 80 - 22000 Hz - SNR - 98 dB
Frequency Response
80 - 22000 Hz
Signal-To-Noise Ratio
98 dB
Output Power / Total
40 Watt
Input Impedance
50 kOhm
Input Sensitivity
500 mV
Total Harmonic Distortion
1.0%
Amplifier Output details
20 Watt - 8 Ohm - 2 channels (main)
Display
Display Type
LED display
Remote Control
Remote control
Connectors
2 x audio line-in , Speakers output
AC power adaptor, audio cable, remote control, speaker cable
2 x speaker cable - 5 m , 2 x audio cable - 15 cm
Power adapter - external
4.2 cm
4 cm
7.1 cm
63 g
Width (Shipping)
23 cm
Depth (Shipping)
6.3 cm
Height (Shipping)
10 cm
Weight (Shipping)
1 kg
