Vision SP-1100P Active Speakers 20w
Quicklinx: 9C0CWS00 Mfr#: SP-1100P
Designed for use in small meeting rooms and classrooms, the SP-1100P are Vision's most cost-effective audio solution and represent fantastic value. Great sound quality and Vision's trademark ease of installation are key features of this product.
  • Digital
    The SP-1100P is assembled by a fully automated production line to ensure reliability, and uses a quality Yamaha class-D digital amplifier chip.
  • Volume on front
    The volume dial is on the front of the 'master' loudspeaker - the one containing the amplifier - so users can easily access it. Turning the volume dial fully anti-clockwise turns the power off (standby).
  • Flexible connectivity
    The rear panel of the master loudspeaker offers minijack and 2-phono inputs.
  • MDF fabrication
    A sturdy MDF chassis provides a rigid acoustic chamber for distortion free sound, and the tuned bass reflex port enhances bass.
  • Summed inputs
    The two line-level inputs are combined at the input stage meaning there is no input selection switch. When both inputs are used it is especially important that all source and display devices in the system are powered from the same mains power source.
  • Silk tweeter
    A proven two-way design with good quality driver components ensures users will get reliable service for many years.
Vision SP-1100P - speakers
Speakers
System Components
2 speakers
Speaker Type
2-way - active
Nominal Output Power (Total)
20 Watt
Frequency Response
80 - 16000 Hz
Amplifier
Integrated
Speaker System Details
2 x speaker 10 Watt - 80 - 16000 Hz - 4 Ohm
White
AC 230V
14.5 cm x 15 cm x 22 cm
Speakers
Enclosure Colour
White
Enclosure Material
MDF
Speaker System
System Components
2 speakers
Speaker Type
2-way - active
Audio System Continuous Power (Total)
20 Watt
Frequency Response
80 - 16000 Hz
Sensitivity
85 dB
Amplifier
Integrated
Recommended Placing
Wall-mountable
Controls
Volume
Speakers Included
2 x speaker - 2-way - 10 Watt - 80 - 16000 Hz - 4 Ohm - wired
Driver Details
Speaker: woofer driver - 4" , Speaker: tweeter driver - 1.5" - silk
Connector Type
Audio line-in (RCA x 2) , Audio line-in (mini-phone stereo 3.5 mm)
Wall mounting brackets, speaker cable
Power Source
AC power adapter
AC 230V
14.5 cm
15 cm
22 cm
