Vision AV-1600+CS-1600 Audio Bundle
Quicklinx: 8C8NWS00 Mfr#: AV-1600+CS-1600
Vision AV-1600 is a 4 channel digital Stereo mixer amplifier, the AV-1600 amplifier is compact, flexible, easy to use and uses no power at idle. It is rated at 2 x 25 W RMS per channel at 8 ohms impedance the digital. The Vision 25 W stereo AV-1600 power amplifier includes 4 x stereo inputs/1 x stereo pre-output/1 x balanced microphone input with phantom power.
The CS-1300 ceiling speakers feature a two-way design offers a full-bandwidth delivery full of control and clarity. The main driver is a 6.5" polypropylene cone, complimented by a Ferro-fluid cooled silk tweeter set in a swivel mount for fine tuning of the stereoscopic image. These low impedance speakers don't sacrifice frequency range in the way that the transformer on 100/70 V speakers inherently do, meaning lower bass extension and higher treble without distortion. These speakers are a perfect alternative for situations where wall speakers are not appropriate.
  • AV-1600 FEATURES:
    Mounting earsAV-1600 included mounting hardware allows attachment of the Vision AV-1600 to a wall, projector pole, or rack. It has 1U/half-rack-width chassis.
  • Touch control
    The input and power on/off buttons on the AV-1600 is sleek touch buttons. The backlit dials are clear and easy to use. Useful LED indicators show the volume levels even in low light environments.
  • Flexible inputs and output
    The microphone input on the Vision AV-1600 uses a professional balanced XLR connector, to eliminate the electromagnetic noise induced on long cable runs and comes with "Phantom Power" the required voltage for the microphones used on desk and conference and other sensitive condenser microphones.
  • Amp with ceiling and ground lift switch
    A unique feature of this amplifier is the ability to be used in tandem with a data projector to the ceiling, using the projector's remote control to select inputs and adjust the volume of the Vision AV-1600. The AV-1600 is equipped with an AC current output, which allows the amplifier to the projector and use the same socket, and a ground-lift switch to eliminate noise on the audio signals sometimes led by data projectors. Simple!
  • CS-1300 FEATURES:
    High sound pressure levelsThe net result is it's harder to use the volume of air behind the speaker to reinforce the sound coming out the front - which is what a bass reflex does in traditional chassis speakers. Because of this ceiling speakers inherently lack power at the bottom end, so they've tuned these to have a slightly louder sensitivity of 89dB to punch through high-noise environments.
  • Simple to fit
    Simple to mount into false ceiling tiles, the CS-1300 is the audio contractor's ultimate product for ease of installation. Get a 210mm hole-saw from your local hardware supplier, drill a hole, and fit the speaker! It's clean and easy.
  • Tune to the environment
    The crossover design provides the CS1300 with superb off-axis dispersion characteristics, and the contemporary grille design makes the finished installation less intrusive than others in its class. Best of all the CS-1300 has been tuned to compliment all the Vision amplifiers.
Vision AV-1600 - audio system
Audio system
Components
Amplifier, speaker system
Audio Channels
Stereo
Audio Specifications
Amplifier - 50 - 17000 Hz - 75 dB
Frequency Response
50 - 17000 Hz
Output Power
50 Watt
Speakers
2 x speaker - 70 - 20000 Hz
Audio system
Audio System
Components
Audio Channels
Stereo
Functions
Amplifier
Amplifier - Response Bandwidth - 50 - 17000 Hz - SNR - 75 dB
Frequency Response
50 - 17000 Hz
Signal-To-Noise Ratio
75 dB
Output Power / Total
50 Watt
Input Impedance
47 kOhm
Input Sensitivity
400 mV
Total Harmonic Distortion
2%
Amplifier Output details
25 Watt - 4 Ohm - 2 channels (main)
Phantom power
Speaker System
Speakers
2 x speaker - 2-way - 70 - 20000 Hz - 8 Ohm - wired
Driver Details
Speaker: 1 x woofer driver - 6.5" , Speaker: 1 x tweeter driver - 1" - silk
Detachable Grilles
Connectors
4 x audio line-in (RCA x 2) - rear , Microphone (XLR) - rear , Audio line-out (RCA x 2) - rear
Components Colour / Material
Amplifier - black , Speaker system - white
Mounting hardware, audio cable, speaker cable
2 x audio cable - 2 m , 2 x speaker cable - 5 m
Power supply - internal
100 Watt
Dimensions (WxDxH) / Weight
Speaker system: speaker: 23 cm x 12.8 cm 1.6 kg , Amplifier: 22 cm x 16.5 cm x 4.4 cm / 1.2 kg
