Veho Waterproof wireless speaker phone/tablet charger- Orange
Quicklinx: BHM4WS00 Mfr#: VXS-002-ORG
The wireless Vecto speaker from Veho has been designed for the outdoor lifestyle. With its rugged robust chassis and water resistant housing the Vecto speaker is the perfect companion for camping, festivals, trekking, sailing, the beach, picnics or lazing by the pool.
Connect your wireless Bluetooth device, such as your smartphone, tablet or MP3 player, using the NFC quick pair and enjoy the Vecto's 8 watts of high fidelity sound. Multi-task and never miss a call with the integrated microphone or use the built in MP3 player and microSD slot and take your tunes with you.
Not only is the Vecto a speaker but it also houses a powerful 6000 mAh power bank to recharge your smartphone over 4 times or top up your other USB charged devices such as torches, GPS, action cameras when you are away from mains power.
Veho 360 Vecto - speaker - for portable use - wireless
Speaker - for portable use
Media Content Source
Flash memory card
Protection
Waterproof
Speaker Type
Active
Continuous Power
8 Watt
Amplifier
Integrated
Bluetooth, NFC
Speaker Details
Speaker - stereo x 2 - 4 Watt - active
Orange
Power Options
USB charging
Speaker battery rechargeable
14.4 cm x 6.1 cm x 8 cm
304 g
Flash memory card
Hands-Free Function
Protection
Waterproof
Enclosure Colour
Orange
Speaker System
Speaker Type
Active
Continuous Power
8 Watt
Amplifier
Integrated
Bluetooth 4.0, Near Field Communication (NFC)
Recommended Placing
Outdoor
Controls
Volume, next track, previous track
Speaker System Details
Speaker Details
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , DC power output (4 PIN USB Type A)
Audio cable, carabiner clip, USB charging cable, protective pouch, microSD Card (4GB)
Power Source
Options
USB charging
Rechargeable
Capacity (Ah)
6000 mAh
Run Time (Up To)
20 hours
14.4 cm
6.1 cm
8 cm
304 g
